Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-25-2015, 02:44 PM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Adding a Console USB Power Port to my 2007 Sport
Update: Though one of the ports in the unit I first installed provides 2.1A, turns out I need a more powerful option in practice. For example, when traveling, we have multiple devices to keep charged and the originally installed port can't keep up.
Based on another member's recommendation, I have replaced the original USB ports listed in this thread with a Blue Sea 1039 4.8A model. Some minor tailoring of the switch opening was necessary but I've been very pleased because the Blue Sea port provides all the power needed.
Here’s the Blue Sea installed. Wiring is the same as described in my original post below.
Original Post
Others have done this but for what it's worth, here's my experience with adding USB power ports in my 4th gen 4Runner. It's a very easy mod that didn't take 2 hours total despite the problems with the plug, painting, etc.
I first used this product, which definitely presented some challenges as described in my Amazon review.
But all's well that ends well so here is the story. Fortunately, it's very easy to install and access the port so that made the problems much more tolerable.
1. I used quick splices to tap into the 12V power port outlet in the console. Considered using an add-a-circuit but this worked fine. Like the power port, the USB port is controlled by the ignition. Things to keep in mind - as others have noted, be sure the wire you're placing into the quick splice is all the way in and squeeze the metal part all the way down, and be aware that the quick splice things have this conductive jelly stuff in them (much like Vaseline) so have a rag or paper towel handy to wipe your hands before handling any other parts. (Edit: use Scotchloks if you can, they work much better.)
New edit: This pic was taken with everything plugged back in and ready to reassemble. Before you start the wiring part, just unplug the white power port plug and blue DAC switch plug. Each has a locking tab on one side and may be tight, so squeeze the tabs and gently work them until they come out. Then lay the big console piece aside and you'll have the space you need to work.
2. Here's how the port looks if installed as sold. It fits the opening perfectly but isn't anywhere close to a match for the OEM switches. BTW, I saw a question about how the OEM plugs come out of the openings in another thread. It's simple, they're held in by tabs and easy to remove.
3. The blue light won't even be noticed by some owners but will probably seem like a blinding blue death laser to others. I fell in the middle. It's not awful but it's at the bottom right limit of my peripheral vision so it was kind of irritating at night. Pics don't do it justice...it's not that passive for lack of a better word, it's pretty bright. See solution below.
4. Since I didn't like the shiny finish, I decided to take the port out and paint the easily removeable cover to better match the OEM switches. Two light coats of flat black and one light coat of a clear matte protective finish (figured it would help the paint hold up better in the long run) did the trick. Wasn't worried about covering the USB logos and figured it might help with the blue light too.
5. Painted and reinstalled.
6. It did help with the light. I've also ordered black dust plugs which will block it completely and keep gunk from getting down into the ports. I'll post an updated pic once those come in.
If anyone has any questions, fire away.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 02:52 PM #2
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
Very nice install. Thank you for the write-up!
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 03:44 PM #3
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
Nice write up! Thanks!
46runner is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 06:37 PM #4
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Looks stock. Nice job.
Morphyne is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 06:40 PM #5
v_man's Avatar
v_man v_man is offline
v_man is on a distinguished road
v_man's Avatar
Nice work...
v_man is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 11:05 PM #6
dagen's Avatar
dagen dagen is offline
Real Name: Sean
dagen is on a distinguished road
dagen's Avatar
Real Name: Sean
Nice! I installed one of the exact same just the other day! I like your idea of painting the top trim piece flat black. I think I'll pull mine and do the same. I wasn't really all that jazzed on the blue LED's or the gloss.
'06 Sport V6 4x4, Icon Stage II, Gobi Stealth Rack, Shrockworks Sliders, Shrockworks Front Bumper, Comeup 9.5rs, RCI Aluminum Skids, 285/70/17, ARB CKMA12, Icom 2730A
dagen is offline   Reply With QuoteReply With Quote
Old 10-26-2015, 01:23 PM #7
magert54's Avatar
magert54 magert54 is offline
magert54 is on a distinguished road
magert54's Avatar
Do you all know if the DAC can be moved to the panel on the left of the vehicle. I dont have room for this mod and i dont use (dont know how to turn on) the DAC.
2006 4.7L V8 SE
Build Thread Colorado
magert54 is offline   Reply With QuoteReply With Quote
Old 10-26-2015, 03:05 PM #8
Kyle C's Avatar
Kyle C Kyle C is offline
Kyle C is on a distinguished road
Kyle C's Avatar
Looks good OP. I installed mine about 3 weeks ago. I love what you did with the black paint, I should do that.
The way I solved the blue LED issues was to pull the little circuit board out of the casing and desoldered the LEDs. No harm, no fuss and no annoying light!
'04 4Runner Sport V8 4x4
'16 Commencal META AM V4 Race
Canon 6D w/ML & Sigma 24ART, 50L, 135L, & lots o' filters
Kyle C is offline   Reply With QuoteReply With Quote
Old 10-27-2015, 05:32 AM #9
Bluesky 07's Avatar
Bluesky 07's Avatar
Thanks to all who have commented. I really wanted the port to look as stock as possible and it turned out about as well as I could have hoped.
About this question, the best I can do is maybe. The switch should fit fine in one of your open spots, but the issue would be whether the wire bundle to the switch is long enough to reach. I don't know the answer to that.
Old 10-27-2015, 04:39 PM #10
grapemilk's Avatar
grapemilk grapemilk is offline
Real Name: Sean
grapemilk is on a distinguished road
grapemilk's Avatar
Real Name: Sean
Looks great. I'm going to install mine this weekend. Great tip about painting the top cover. I'm planning to swap out the LEDs for some orange ones.
grapemilk is offline   Reply With QuoteReply With Quote
Old 10-28-2015, 03:17 AM #11
magert54's Avatar
magert54's Avatar
Its a great mod, keep up the great ideas
2006 4.7L V8 SE
Old 10-28-2015, 06:49 AM #12
Freyer's Avatar
Freyer Freyer is offline
Freyer is on a distinguished road
Freyer's Avatar
Very clean. Well done!
Freyer is offline   Reply With QuoteReply With Quote
Old 10-28-2015, 07:11 AM #13
JET4 JET4 is offline
JET4 is on a distinguished road
Nice
2018 Magnetic Grey Metallic
2011 Salsa Red TE W/KDSS & Nav 275/70R17
2007 White Toytec lift 285/70R17 (sold )
1999 Imperial Jade Mica SS lift 305/17R16 (sold)
JET4 is offline   Reply With QuoteReply With Quote
Old 10-28-2015, 10:14 AM #14
lcbjr77's Avatar
lcbjr77 lcbjr77 is offline
Real Name: Larry
lcbjr77 is on a distinguished road
lcbjr77's Avatar
Real Name: Larry
I wanted a USB to always stay on while my vehicle is off. I assume I could use this https://www.youtube.com/watch?v=xn8eZjSskms with the USB Power Port you have in your post
2007 4RUNNER LIMITED 4.0 V6
DRIFTWOOD PEARL
Xenon Depot 4300k Philips HID Kit
Weathertech floor mats
lcbjr77 is offline   Reply With QuoteReply With Quote
Old 10-28-2015, 03:02 PM #15
Bluesky 07's Avatar
Bluesky 07's Avatar
With the caveat that I'm no electrical expert, an Add-a-Circuit should work fine, granted of course you plug it into a constant-power slot. Also, when you buy one, make sure to get the one that fits the smaller-sized slots. I goofed the first time and bought the bigger one.
Replacing power adapter /cig lighter port on a '98? farmerjon 3rd gen T4Rs 12 08-21-2021 10:30 PM
2010 SR5, adding power to center console Hoxtongue 5th gen T4Rs 3 11-12-2013 06:22 PM
Possible power port location? Narkhelek 5th gen T4Rs 2 06-28-2012 09:17 PM
15 minute power port install 3x 12v with USB Asmara 4th Gen T4Rs 13 08-06-2010 12:46 PM
Adding Tranny gauge - what size lines or port? TeryT Maintenance/Detailing 0 03-14-2005 07:44 PM
