Old 07-20-2016, 05:13 PM #1
EdmundGTP EdmundGTP is offline
EdmundGTP will become famous soon enough
Originally Posted by Civiceg94 View Post
I though about the same thing. To put spacer. The way it came from icon i like the way it rides. Am afriad if i crank it up a bit itll change the way it rides.
It will change the way it rides.
Another thing to consider. The coilover assemblies designed for our trucks have a specific length when fully extended. That length is determined by the optimum travel range of both the suspension linkage, and the operation range of the CV joint. Adding a spacer on TOP of the coilver may likely forces the knuckle droop to be further than what the CV can accommodate. I.e. extreme CV angle when either of the front wheels is nearly unloaded.
Consider the scenario in which you're climbing up uneven terrain. One of your front wheels completely unloads and that CV angle is now way past the normal operating range because of the top spacer you added. ATRAC kicks in, and locks the brake at that same corner, and now your drivetrain is transmitting intermittent torque through a CV who's angle is very close to, or maxed out. Bye bye CV joint.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
EdmundGTP is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 06:41 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
You're much more likely to over-stress the CV by turning sharply than you are by any reasonable amount of suspension droop. The front wheels have a maximum turning angle of around 30 degrees. To get that much of a CV angle with suspension droop would require a droop of about 7-8 inches from horizontal at the wheel. A 1" spacer isn't going to get you to that point. You'd have to do a roughly 4" spacer-only lift to get those kind of angles.
It's also worth noting that preload does not change the stiffness of a spring. Stiffness is set by spring materials and construction. Consequently preload, whether done by raising the spring perch on the shock, or by inserting a spacer at the top of the shock, does not change the ride at all unless you shift the ride height so much that you are hitting the bump stops or exceeding the shock travel. As long as the preload does not exceed the vehicle weight (which case would prevent the suspension from getting off the lower stop), the spring operating point does not change, regardless of preload. It is still the same stiffness spring, and it is still supporting exactly the same amount of weight, therefore its loaded length will be exactly the same as it was before the preload change.
Preload does bias the suspension operating point away from center. Where spacers and other lift options cause trouble is when the suspension nominal operating point is biased too far from its center value, causing the suspension to frequently hit the stops on one end or the other, or causing the spring to go into coil bind before the stops are reached. As long as neither of those situations occur, the ride should be indistinguishable from the non-preloaded case.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 07:36 PM #3
Civiceg94's Avatar
Civiceg94 Civiceg94 is offline
Civiceg94 is on a distinguished road
Civiceg94's Avatar
so how are the people on this forum reaching heights of 39 inches without complaining about cv angles and also vibration from having the cv at weird angles?
Icon extended travel coilover, Icon 2.0 rear shock, Ome 895e rear spring, Camburg balljoint control arm, 285/70-17 Toyo open country at2, SCS F5 17 inch gloss sliver, Energy Suspension bushing sway bar & front lower control arm, Viair 2gallon air compressor, DDM Tuning 55w hid low.
Civiceg94 is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 08:29 PM #4
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Just like I stated, you run a taller spring. Stock icon spring is 13" I believe. They have an option to order with a 14" spring or you can order 14" springs from king.
I'm sitting at almost 41" ground to fender and have like 1" of thread showing.
I have a gx470 and it comes with a negative CV angle from the factory so lifting it is pretty simple. I also do not run a diff drop and have zero issues with CV joints or vibration.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 09:56 PM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I'm at 40" ground to fender with a 1.5" BL and 33's. Longer 700# King coils and 1" of thread showing. CV angles are awesome with the diff drop but front skid plate needed lowered a bit.
People should stop measuring from the ground and start doing it from the center of the hub or something that way tire sizes and wear won't factor in.
@GX4SEVEND has 35's which screws up the comparison.
2005 4R "The last of the V8s!" - TC +2 LT. - Lockers Front & Rear - 37's - Dana 60 - Build Thread
2005 Tundra 2WD Regular Cab 4.7L - Chopped Frame - Short Bed Swap - Lowered
2019 Tundra 4WD Double Cab 5.7L My Website: Full Metal Designs
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 11:01 PM #6
Real Name: Ron
Real Name: Ron
Running taller springs will have the same effect on the CV as a tall spacer. The CV only cares about the relative height of the differential compared to the center of the wheel. That's why people with large lifts do diff drops.
CV vibration may well occur at smaller angles than 30 deg, but my post was originally about breakage, not vibration. Not many people crank their steering wheels to full lock while going fast enough for vibration to be a factor, at least and live to tell about it.
Just went out and did some measurements on my stock '06 Sport, to put some science into this. The CV joints are 12 inches apart, and the CV offset is a negative 1.5 inches. That gives a CV angle of 7 degrees. Fender height is 34 inches. If I lifted to 40 inches without moving the diff, the CV offset would go to a positive 4.5 inches. That would be a CV angle of 20 degrees, still a lot less than the maximum steering angle. Dropping the diff 1.5 inches would make the CV angle a mild 14 degrees. That's assuming the entire lift was a suspension lift. If part of it was a body lift, which doesn't raise the diff, the angles would be even better.
Old 07-21-2016, 05:09 AM #7
BOFFROAD's Avatar
BOFFROAD BOFFROAD is offline
Real Name: Brad
BOFFROAD is an unknown quantity at this point
BOFFROAD's Avatar
Real Name: Brad
Thanks for replies. I'd rather not put too much angle on the CV's so I'll ditch the spacers and I will try giving the collars a few more turns. If thats not enough I will begin looking for 700# springs if they don't cost too much.
2005 Sport V8 4WD Gray
Icon Stage 2 | 285/70/17 BFG KM2 | MB 352 17x9" wheels | 42" led light bar | Side Flood/Camp Lights | Uniball UCA's | K&N CAI | Kicker Sub and Amp | Custom DIY Full Length Roof Rack | Trail Gear 67"
Rock Sliders
Build Thread
BOFFROAD is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 09:15 AM #8
Civiceg94's Avatar
Civiceg94's Avatar
Ill call icon one of these days and see what they say.
Old 07-20-2016, 08:08 PM #9
By that reasoning, wouldn't a 3" coilover lift with a 1" spacer on top of it get you damn close to it?
What about an over max suspension droop PLUS turning the wheels?
bumpstop , icon , lift kit , spacer , suspension
Trd pro suspension vs icon?? Desert36 5th gen T4Rs 90 10-04-2016 11:20 PM
Anybody know what small spacers with dif drop kit r for? direwolf74 3rd gen T4Rs 2 06-07-2015 09:33 PM
Stacking spacers on Icon Coilovers JustSomeName 4th Gen T4Rs 12 01-10-2014 09:15 AM
ICON Suspension for 4th Generation - Icon Stage 6 WOLVERINE Want to Buy/Trade 2 02-18-2013 01:39 PM
Icon install. opps small mistake. ejason 5th gen T4Rs 0 05-02-2012 12:14 PM
