Prev Previous Post   Next Post Next
Old 07-20-2016, 11:01 PM #13
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Running taller springs will have the same effect on the CV as a tall spacer. The CV only cares about the relative height of the differential compared to the center of the wheel. That's why people with large lifts do diff drops.
CV vibration may well occur at smaller angles than 30 deg, but my post was originally about breakage, not vibration. Not many people crank their steering wheels to full lock while going fast enough for vibration to be a factor, at least and live to tell about it.
Just went out and did some measurements on my stock '06 Sport, to put some science into this. The CV joints are 12 inches apart, and the CV offset is a negative 1.5 inches. That gives a CV angle of 7 degrees. Fender height is 34 inches. If I lifted to 40 inches without moving the diff, the CV offset would go to a positive 4.5 inches. That would be a CV angle of 20 degrees, still a lot less than the maximum steering angle. Dropping the diff 1.5 inches would make the CV angle a mild 14 degrees. That's assuming the entire lift was a suspension lift. If part of it was a body lift, which doesn't raise the diff, the angles would be even better.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
bumpstop , icon , lift kit , spacer , suspension
Trd pro suspension vs icon?? Desert36 5th gen T4Rs 90 10-04-2016 11:20 PM
Anybody know what small spacers with dif drop kit r for? direwolf74 3rd gen T4Rs 2 06-07-2015 09:33 PM
Stacking spacers on Icon Coilovers JustSomeName 4th Gen T4Rs 12 01-10-2014 09:15 AM
ICON Suspension for 4th Generation - Icon Stage 6 WOLVERINE Want to Buy/Trade 2 02-18-2013 01:39 PM
Icon install. opps small mistake. ejason 5th gen T4Rs 0 05-02-2012 12:14 PM
