Will OME 885s fit over Bilstein 6112s
07V8
Can anyone confirm whether or not the 885s will fit over the large OD of the 6112s. I'm getting a Bumper and want to get the appropriate spring instead of preloading the stock Bilstein springs.
Looks like the 6112's come with your choice of 600/650/700lbs coils.
The OME are 2.5" at smallest diameter, bottom.
As are the stock coils...2.5"...and Rancho, not sure that helps any.
Best bet is to contact Bilstien and get the spring diameter
Unless something has changed I understand they all come with 600lb coils. If you want 650 or 700 you have to buy them after the fact.
The point being they are available but not part of a standard sku you can order as a kit without the 600lb coils.
Yup, looks like your right, my bad.:toilet3:
