I installed this USB outlet because I wanted an "audio" only USB connection to use to connect to my HU for CarPlay.
Mictuning Toyota USB Charger with Audio Input/Adapter - 6.6ft Power Wire, 3.9ft Audio Wire (Stereo USB Connector Needed) https://www.amazon.com/dp/B013W8LQ7C/ref=cm_sw_r_cp_apip_BJyULMcer3AwH
It works great, except when I use GPS there's not enough juice to charge my phone, I get a drain.
Is there any way to either get more power to this connection or if I buy another is there something I should look for to confirm it will be robust enough to pass enough power through the cable?
Thanks!
Thanks!
