Power steering question
Tigerfan86
ok i have a 2004 limited 4x4 with the v-8 . with the hood up just before the radiator, one of the power steering lines i think its the non pressured lines "clamps on both ends" seems to be leaking. there is oily residue on the ends combined with dirt from everyday use. I've tried looking at the lines with somebody turning the wheels from lock to lock and i dont see it leaking but im having to add fluid every other month. I need help as this happened to anyone else, or do i need to replace the return line there like 40 bucks at local oreillys?
If it's a non pressure line, just pull it off and go to your local auto store with it to find the correct diameter hose to replace with. Cut to length, get new clamps and you should be good.
