Old 12-30-2018, 10:53 PM #31
yotaguy674's Avatar
yotaguy674 yotaguy674 is offline
Real Name: Caleb
yotaguy674 has a spectacular aura about yotaguy674 has a spectacular aura about
yotaguy674's Avatar
Real Name: Caleb
Is anyone else not seeing any pictures?
2006 T4R Sport 4x4 V8 My Build
1.5 AllPro wheel spacers, Bilstein 5100's with OME 886's with 1/4" Toytec spacers, OME 2896 rear coils, SPC UCA's, LT285/70-17 BFgoodrich KO2's on 2016 wheels, ARB on-board air system, LFD Off Road Skid Plate, DV8 Offroad Tacoma steel bumper with Smittybilt XRC Winch, PIAA 530 Fog Lights, Diff Breather Mod, Limited grille, CBI ditch light brackets and light pods, ARB awning, Wilco Offroad Tiregate,Full size spare tire, RCI Rock Sliders, HCF delete, Smokers kit, Interior LED swap, Map light mod, Pionner AVH-X391BHS HU, Tentbox RTT, Cobra CB, Flowmaster exhaust
yotaguy674 is offline   Reply With QuoteReply With Quote
Old 12-30-2018, 11:53 PM #32
Primetime4370's Avatar
Primetime4370 Primetime4370 is offline
Primetime4370 will become famous soon enough
Yeah, I've noticed a lot of broken picture links today.
Primetime4370 is offline   Reply With QuoteReply With Quote
Old 12-31-2018, 12:46 AM #33
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Pearl sitting tall and proud this morning after the BL. Now she needs a Pre Runner/Baja tube bumper.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-pearl-bl-1-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-pearl-bl-2-jpg
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 01-01-2019, 05:35 PM #34
Real Name: Brett
Real Name: Brett
"Pearl's" New Year Shuffle
Maybe, kinda sorta, possibly getting this suspension stuff figured out. Looks like I need more "up".
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
Old 01-05-2019, 10:38 AM #35
Real Name: Brett
Real Name: Brett
Rear Suspension Test #2
Removed the Super Bumps mounting bracket and bolted them right to Metal Tech extension blocks. Gained about an 1.25" up travel. A lot less like a Pogo Stick now. @LTDSC Thanks for the Tip Sam!
Old 01-05-2019, 10:45 AM #36
Real Name: Brett
Real Name: Brett
TC Dual Front Suspension Test
System is working really well! Travel is taking the tire up into the inner fender well so I might need a 1/2" or so bump stop extension lol. @TOTAL CHAOS The amount of travel for stock length is amazing!! Thanks for the Great Products!!
Old 01-10-2019, 10:39 AM #37
Real Name: Brett
Real Name: Brett
A little speed in the choppy stuff
Old 01-12-2019, 08:16 AM #38
Real Name: Brett
Real Name: Brett
Noticed my trans temps getting up over 200* when pushing hard through the thick sand. After sitting, Trans would cool back down in about 10 minutes.
But, there are times when you get in a position where it's really hot and there isn't much air moving across the cooler, and your not able to park and let it cool off. One example in this Florida heat is bumper to bumper traffic after exiting an interstate will usually result in sustained temps over 200*, especially with the A/C running. Trans brake will actually raise temps a little as your exiting down the ramp.
So I installed a little helper (Spal 4" pusher fan-3A draw and 124 cfm) on the factory cooler. I might go bigger cooler and fan one day but I figured this was cheap insurance in the mean time. I decided not to mess with an auto/temp switch so I can control it if I ever have alternator issues on the trail. Used an aftermarket push switch off amazon that fits in an empty spot on the left side bank of dash switches.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-trans-fan-3-jpg
Used galvanized plumbing/hanger strap from Home Depot.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-strap-jpg
Old 05-27-2019, 01:31 PM #39
Real Name: Brett
Real Name: Brett
Having a bumper fabbed up soon, so the cover got deleted. Cheap LED marker lights for signals and 1/4" mesh for protection.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20190525_201154_hdr-1-jpg
Old 05-27-2019, 04:09 PM #40
montijo505's Avatar
montijo505's Avatar
Super jealous of your suspension lol, good work. I’ll be following!
Old 05-28-2019, 10:19 AM #41
Real Name: Brett
Real Name: Brett
Thanks, basically copying the Cali boys quite a bit. East Coast is so far behind with suspension tech. I learned about King, Total Chaos, and CaliFab rear links from some of the 5th gen guys, but when I started digging into 4th gen threads, @LTDSC has one of the baddest Runners of all the generations. But anyway, not into building a typical Florida mud truck, thats been done to death and Ih8mud to boot. I like SPEED! Gimme several miles on a power line rd at 40 to 60 mph and I'm in heaven. I do wish I had sucked it up and done the LT front instead of the dual set up. I still have a lot to learn, but I don't think the stock length can keep up with the rear suspension.
Old 08-01-2019, 04:10 PM #42
Real Name: Brett
Real Name: Brett
Baja Bumper nears completion/Apex Fabrication/Troymclure design
@Troymclure @LTDSC They say imitation is the sincerest form of flattery. Or you could say I'm just ripping you off. Killer design Jake!! This thing is really stout and the vertical tubes aren't even installed yet.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20190801_144823-copy-jpg
Old 08-02-2019, 06:10 PM #43
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
its definitely a great look and perfect for what i needed.
Looks good!
LTDSC is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 06:50 PM #44
Real Name: Brett
Real Name: Brett
Looks good!
Thanks! I think it definitely looks better with the LT and bigger fenders on your Truck, so the boys at Apex made some small adjustments to bring it in to match the standard length. My uprights are narrower than yours for sure, and they chopped a 45* in the lower portion today for a better approach angle. Very happy with it though.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20190802_143159-jpg
Old 08-03-2019, 10:53 AM #45
Real Name: Brett
Real Name: Brett
Sand, acetone, primer and paint. Doing the core support as well. Hoping the rain holds off.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20190803_093637_hdr-jpg
1UZrunner build page 1UZrunner Gallery 6 12-01-2023 10:49 AM
Ruggedly Elegant Golden Pearl Build RUGGED Elegance 3rd gen T4Rs 113 02-14-2023 01:00 PM
A10MileHusker's 4th Gen Build Page A10MileHusker 4th Gen T4Rs 247 07-17-2017 01:25 PM
Stell4R's Blue Pearl Build (really its for maintenance) stell4r 3rd gen T4Rs 29 07-13-2017 01:42 PM
Twelve1 build page twelve1 5th gen T4Rs 4 02-26-2014 02:41 AM
