08-03-2019, 11:34 PM
#46
Real Name: Brett
Real Name: Brett
Feelin mischievous.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
08-04-2019, 09:42 PM
#47
Real Name: Brett
Real Name: Brett
Bumper
Not sure about the color I painted it, but loving the look!!
09-12-2019, 11:02 AM
#48
Real Name: Brett
Real Name: Brett
Rear Bumper Cover Delete
Continuing my assault on plastic covers. There are none on either the 4th or 5th gen. The hate is real lol.
09-12-2019, 12:26 PM
#49
What kind of rear you gonna run? I’ve been keeping up with the build and she’s coming along nicely. With your suspension set up, anything else you do to it is just icing on the cake!
09-12-2019, 03:50 PM
#50
Real Name: Brett
Real Name: Brett
@ montijo505
Thanks! It keeps me outta trouble. No plans for a bumper, well maybe some decals like my 5th gen.
09-12-2019, 04:44 PM
#51
Awesome! That's a lot of shockage going on there lol
Here is everything mocked up (pass. side) with the hub installed. Have to put on roller tires for the tow truck over to the weld shop. Anthony over at Apex Fabrication-Merritt Island, will be ready to go on Monday. Still have to put the drivers side together over the weekend. I've outlined a couple tips for the tower gussets and where the reservoir brackets and the Boss (lower hoop support to the frame) gets welded to the shock hoop and frame.
@TOTAL CHAOS
everything is going together quite nicely w minimal cutting and grinding on the tower gussets. Thank You!!
01-29-2020, 07:01 PM
#52
Real Name: Brett
Real Name: Brett
Waiting on hardware for my headers so I did some ugly grill make over. Had the paint laying around. Don't know if I like the red...
02-07-2020, 10:23 AM
#53
Everything you've accomplished is low on the Suck Factor! Well done!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
02-07-2020, 10:37 AM
#54
Real Name: Brett
Real Name: Brett
Anyone else not see the pics on their phones? I see them on my pc, just not on my phone.
02-07-2020, 10:44 AM
#55
No pics for me.
02-07-2020, 10:50 AM
#56
Real Name: Brett
Real Name: Brett
Originally Posted by Inv4drZm
No pics for me.
Copy that, back to the edit room. For some reason I can't post pics in sequence with captions anymore. I think people tend to get more info out of seperate pics that have descriptions for each one. Guess I could jack my post count up.
02-07-2020, 11:25 AM
#57
Real Name: Brett
Real Name: Brett
DT LT Header install-remix
Sorry I messed up my formatting on my earlier header post, I used to be able to post pics with captions and forgot how or the site has changed. I will put these in series:
So with a TC/King dual shock set up w tower gussets done a year before the header GB, access to headers would be even more limited in an already tight space to work in. I had to decide whether to do the job myself or have my buddies (3rd Gen owner) shop do it. He glanced it over and said it might prove to be a good idea to pull the engine and replace rear seal (150K miles on truck), starter and a few other odds and ends. Timing belt only has 15k miles on it.
With my retirement looming in the next 10 years, I have to quit dumping money into these trucks and start saving lol. So I opted to go the painful route of doing it myself.
I have to say Doug Thorley's instructions were pretty helpful and I muddled my way through it. Took me 2.5 days working for a couple hours at a time so as not to get frustrated and make stupid mistakes.
02-07-2020, 11:26 AM
#58
Real Name: Brett
Real Name: Brett
Titanium hardware from Titanium Works: 1/2" 12 point nuts with #4 allen studs.
02-07-2020, 11:27 AM
#59
Real Name: Brett
Real Name: Brett
I hit all the hardware with Sea Foam Deep Creep a couple times the day before I started. First I raised the Runner on jack stands and removed the y pipe from the oem manifolds, removed the King secondaries, and then removed the driver side heat shield. I removed the CAI, then two bolts for the lower motor mount and jacked the passenger side of the engine up 2" and removed the 2 dip stick tubes and the heat shield.
02-07-2020, 11:29 AM
#60
Real Name: Brett
Real Name: Brett
Working around the tower gussets to access the bolts behind it proved to be quite the socket attachment puzzle. Gaining the right angle with the right swivel attachments combined with a long extension and breaker bar was a brain teaser, but the Sea Foam did it's job and even with extreme angles they all came loose. I hit the studs with another shot of Sea Foam as they had to be removed with just as much care using a 7mm socket and the menagerie of extensions and swivels and a breaker bar. All this was 3/8" drive because I don't think 1/2" would clear a lot of the angles needed.
