well is the auto LSD on or is it off when the red light comes on saying auto LSD?
keakar
when you push the button is the auto LSD on or is it off when the red light comes on saying auto LSD?
the light is no help at all because it fails to say on or off like any normal person would expect and indicator to say.
im assuming its on "all the time" by default and the red lit "auto LSD" is red to indicate as a warning that it is off, but then why doesnt it just say that :redbrick:
It should be when you press the button and the red light on the dash comes in is when it is then active. It's not even a true LSD, it just tells the TRAC computer to modulate brakes to the rear when it detects slippage on a wheel to act as a limited slip. It will not simply cut throttle when it dectects a slipping wheel like how VSC does it.
