Switch Pro's Mount
CanuckinTX
I know that @tin was working on a sunglasses mount for the 4th gen but that seems to have fallen off the map. How have you guys mounted your switch pros? I would love to buy one of the sunglasses mounts but can't seem to contact TIN. If any of you have a good contact to TIN let me know
Thanks
Sam
Only picture I have but I basically drilled holes and mounted it next to my dac switch.
Sent from my Pixel 2 using Tapatalk
I extended the center diff lock wiring to the center console and then used the hardware to mount it utilizing the holes from the other 3 switches. Worked perfectly and looks clean. And yes, I took a pic while driving which was stupid but that alignment was JACKED after offroading!
I bought a limited "Panel cover rear cover" for the center console and mounted it there.
I mounted one similarly in my center console, but used switch blanks to hold it in place. Not 100% locked in place for whatever reason, but still sturdy. I later ordered the limited center console trim piece to get another 2 switches.
I removed the sunglass holder and flush mounted it in the recess. It sits at a perfect angle, easy to access, and tucks it up out of the way.
Do you happen to have any pictures of this? Would be interested to see this in action - sounds like a nice solution....
Thanks Guys
Luckily I did the limited console swap before my dad sold his Limited. So I am going to go with that option. Thanks for the help.
If you're ever going to run front and rear lockers, I have to say that the console (where a bunch of us have it) is definitely the best spot to be able to flip your lockers on and off as needed. Finally put mine to the test this weekend and it was nice having the front locker switch right within arms reach and not really having to look or reach and allows you to keep your eyes on the spotter/rocks.
I tried three different mounting locations and found the overhead console to be the best compromise for accessibility and security. Prior to having the Switch Pro, I had installed switches on the center console and they keep getting hit by kids, the dog, etc. I still have the DAC switch there which needs to be moved. It was better for us to have power ports in the center console, so I moved the Switch Pro panel up to the overhead console. It works great there and I don't find that it requires much arm or head movement to press buttons on the panel.
I had the same problem with my son hitting my switches in the center so when I moved to the switchpro I made sure all switches but 1 were ignition only so there's no chance of accidentally hitting the air comp or the lockers. My side lights are anytime for camping purposes, but front/rear lockers, air, fog lights, and rear lights are all ignition only.
... had installed switches on the center console and they keep getting hit by kids, the dog, etc. ...
Exactly what I worry about with those center console located switches ...
That's a good idea...
I know this is kind of an old thread but those with the SP did you make your own mounting plate for the power module or did find one online? Any suggestions appreciated.
I made one from aluminum, page 35 of my build thread.
Inv4drZm's Build Thread
Whatever you do make sure its mounted vertically, or at least has a cover over it. SP won't warranty it due to water ingress if it's not mounted vertically. Ask me how I know.
oof, I hate to ask.
That looks really good. I will have to search your thread. When I go to it only shows 19 pages. You know about what post number it was in the thread?
EDIT - Found it. Thanks man
Thanks for the help
oof, I hate to ask.
Thanks for the help
When I click the link it takes me to page 35. It starts at post #524.
I wonder what I'll be doing this weekend...
Expensive carwash repair.
New aluminum mount plate and cover. I'll probably make a fiberglass or carbon fiber cover using the aluminum one as a mold eventually.
Old one:
More progress. I think I'll hold the cover down with something similar to a battery tie-down/strap.
Plugged it all in and it works. The newer switchpro is a little nicer than my old one, RGB button panel, some more higher amperage outputs, separate connectors for the button panel and outputs, and a proper cord for the button panel instead of loomed wires. Some other stuff I'm probably missing.
Tomorrow I'll work on wiring my compressor, its all bolted in already.
Oh yeah, set my dial calipers on my tire and drove off, good thing they weren't Mitutoyo's. Used to use them all the time at my old job. RIP.
Got further on the 'splashproof' cover for my Switchpros this friday evening
Like I said I might eventually make a carbon fiber version so I didn't finish the rough spots too much yet.
