Old 09-29-2017, 01:21 PM #1
euy euy is offline
euy is on a distinguished road
euy euy is offline
rear shocks removal
as the title reads....rear shock removal. i know i know should be super easy but i just couldn't grab the top of the shock with anything in my tool box. its a tight fit. was wondering if there are any tricks or anything that will help. thanks guys!!!
btw....i am pretty handy, put the lift kit in myself (minus rear shocks of course) and did a complete brake job so i can get it done...haha!!
euy is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 01:31 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I thought it was pretty easy...
I used a ratcheting wrench, and a GL10 channellock to hold the shock so it wouldn't turn.
Old 09-29-2017, 02:16 PM #3
kingofthehill's Avatar
kingofthehill kingofthehill is offline
Real Name: Who's asking?
kingofthehill will become famous soon enough
That is exactly what I used last night when I changed my shocks.
2005 4RUNNER V8 4WD -- Sony XAV-AX100 -- Bilstein 5100 shocks -- Wheelers T1/T12 Springs -- 5th Gen Wheels -- 2006-09 Tail Light Conversion -- AFE Pro Dry S -- X2Power 24f -- ScanGauge II...
kingofthehill is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 02:19 PM #4
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Hold the nut on top of the mount first, then thread the strut in till it bites together. Easier than having the strut in, then trying to fish the nut in on top.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 02:41 PM #5
euy euy is offline
euy euy is offline
so really the trick is TRY HARDER...haha. i think i was worried about stripping the top of the shock rod. i'll go in and hit it with some penatrating oil and then try again. thanks guys.
Old 09-29-2017, 02:47 PM #6
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
Vice grip, if you are not saving them for some reason.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 03:07 PM #7
ZebRuaj's Avatar
ZebRuaj's Avatar
Removal. My bad.
Just take the death wheel to it if you aren't saving it.
or adjustable oil wrench (rubber strap ones) if you find one small enough to strap onto the shock to hold it still.
Old 09-29-2017, 05:25 PM #8
Codywilsonfishing Codywilsonfishing is offline
Codywilsonfishing is on a distinguished road
If you are trying to remove the stock shocks and they will be garbage after, then use a visegrip on the upper portion of the shock tube. (If you had xreas then you should position it to where the grip holds the port). Also, use two wrenches inner locked so you can stand and brace your self to get more leverage. Mine were so rusted that the threads broke after 2-3 turns.
Codywilsonfishing is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 05:50 PM #9
ecally ecally is offline
ecally is on a distinguished road
Just cut the bolt off (assuming you are putting new shocks on). Took me less than a minute with a sawzall.
ecally is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 05:58 PM #10
jfry008's Avatar
jfry008 jfry008 is offline
jfry008 is on a distinguished road
jfry008's Avatar
I had to do this to one of mine. The nut was seized up and the top of the rod twisted around.
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//http://www.toyota-4runner.org/4th-ge...ld-thread.html
jfry008 is offline   Reply With QuoteReply With Quote
Old 09-29-2017, 07:28 PM #11
yotaguy674's Avatar
yotaguy674 yotaguy674 is offline
Real Name: Caleb
yotaguy674 has a spectacular aura about yotaguy674 has a spectacular aura about
yotaguy674's Avatar
Real Name: Caleb
Yup, sawzall for me as well!
2006 T4R Sport 4x4 V8 My Build
1.5 AllPro wheel spacers, Bilstein 5100's with OME 886's with 1/4" Toytec spacers, OME 2896 rear coils, SPC UCA's, LT285/70-17 BFgoodrich KO2's on 2016 wheels, ARB on-board air system, LFD Off Road Skid Plate, DV8 Offroad Tacoma steel bumper with Smittybilt XRC Winch, PIAA 530 Fog Lights, Diff Breather Mod, Limited grille, CBI ditch light brackets and light pods, ARB awning, Wilco Offroad Tiregate,Full size spare tire, RCI Rock Sliders, HCF delete, Smokers kit, Interior LED swap, Map light mod, Pionner AVH-X391BHS HU, Tentbox RTT, Cobra CB, Flowmaster exhaust
yotaguy674 is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 11:39 AM #12
4daddy 4daddy is offline
4daddy is on a distinguished road
sawzall
Having same problem with top nut rusted on shock. Stuck cant remove. Bent shock back and forth but will not break. Where exactly do you cut with the sawzall? I cant imagine there is enough space to cut on top of the shock mount to get a blade in there so I am at a loss... Help
4daddy is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 11:42 AM #13
Bumbo's Avatar
Bumbo's Avatar
Knipex Cobra and a ratcheting wrench make quick work of the removal for me.
The Knipex to hold the shaft so it doesn't rotate and the wrench to take the nut off.
I just hit it with some penetrating oil before hand and it came off no problem.
Old 04-09-2019, 12:34 PM #14
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
I cut right through the rubber bushing and shock shaft above the top of the frame rail on 4runner. On my Tundra they were also seized on but there was enough room to make a slit in one side of the nut then rotate the shock 180 degrees and make another slit, this cut the shock nut in half so it could just be tapped off with a flathead. Both methods ruin the shock and mounting hardware, install new with your new shock.
blackoutt is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 04:15 PM #15
Can you see the bushing while cutting through it? Its a 2001 T4R. maybe Im looking at it from the wrong angle....
Leaky ICON rear shocks, what rear shocks to get next?? chmura 4th Gen T4Rs 9 10-25-2016 08:06 AM
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
FS: 4th GEN NEW Radflo 2.0 rear Regular Travel Shocks $350+ship Boulder, CO shocks - HOJeepster For Sale: Suspension/Wheels/Tires 11 01-09-2014 05:26 PM
$14.87 Shocks! Attention Anyone looking to do a LC lift in the REAR! SHOCKS ON SALE! crumpkd For Sale: Suspension/Wheels/Tires 3 08-02-2011 07:36 PM
bilstein shocks removal trouble contradan 4th Gen T4Rs 2 09-01-2007 10:13 AM
