Old 03-17-2023, 06:31 PM #1
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
VSC off, Trac Light, etc. but no check engine
I see this is a pretty common problem, but majority I have found also have check engine light on. I do not have the symptom, and the lights only come off after startup and driving a bit or reaching a certain speed or rpm. Could this still be a faulty gas cap? My code reader doesnt show anything all my other numbers it reads look fine. Any ideas would be great thanks.
BigMike18 is offline   Reply With QuoteReply With Quote
Old 03-17-2023, 07:06 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Probably just needs a zero point calibration done. The below procedure is for 03-04, not sure if it's the same for newer models tho.
VSC LIGHT ON – DTC C1203 – BR005-03 December 4, 2003
Zero Point Calibration of Yaw Rate and Deceleration Sensors Using SST 09843–18040 <-- Nothing but a couple pieces of wire that you connect to the 2 terminals on the OBD2 plug under the dash. Need to be about 12" long each.
When having replaced the yaw rate sensor, deceleration sensor or the ECU, perform the process for zero point of yaw rate and deceleration sensors as shown below.
NOTE:
While performing the zero point procedure, do not tilt, move or shake the vehicle. The vehicle must remain in a stationary condition throughout the entire process. Do not
start the engine and be sure to perform the procedure on a level surface with an inclination of less than 1%.
1. Ensure the shift lever is in “P” range.
2. Turn the ignition switch ON.
3. Using SST 09843–18040 (wires described above), repeat a cycle of short and open between terminals Ts and CG of DLC3 4 times or more within 8 seconds. Verify that the VSC indicator light is lit indicating the recorded zero point is erased.
4. Turn the ignition switch OFF.
5. Be sure the terminals Ts and CG of DLC3 are disconnected.
6. Turn the ignition switch ON.
7. Check that the VSC warning light goes off about 15 seconds after the ignition switch is turned ON.
8. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition switch OFF.
9. Connect the terminal Ts and CG of DLC3 using SST 09843–18040.
10. Turn the ignition switch ON.
11. After turning the ignition switch ON, check that the VSC warning light is lit for about 4 seconds and then starts quick blinking at 0.13 second intervals.
12. After ensuring the blinking of the VSC warning light for 2 seconds, turn the ignition switch OFF.
13. Remove the SST from terminals Ts and CG of DLC3.
Confirm Zero Point Calibration:
Drive the vehicle to confirm there are no re–occurring lights or DTCs.
VSC off, Trac Light, etc. but no check engine-obd2-plug-zpc-jpg
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 06:28 PM #3
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Is your ABS light on as well? If so, pull codes from the ABS system. Not all code readers do ABS, so you'll need one that does.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 03-19-2023, 04:33 PM #4
No ABS light, just vsc trac, vsc off, and traction control
Old 03-23-2023, 03:17 PM #5
Christmas Christmas is offline
Christmas is on a distinguished road
Following! Mine has the same issue, but the zero calibration didn't work.
I tried the zero calibration with a long bit of wire, and again with two paperclips. I see the quoted procedure above mentions a couple of wires. Is that significant? Do two wires need to connect the terminals, or is it suggesting having a 12 inch wire come out of each, and then connect the ends of those together?
Christmas is offline   Reply With QuoteReply With Quote
Old 03-23-2023, 05:22 PM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I must have done the zero cal a couple dozen times on my 03'. Kept coming back in a few days w no CEL. PIA
I already have the trac off switch installed (Here's the write up) for the vsc and trac, so I just leave it off now.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 03-23-2023, 05:32 PM #7
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Couple of separate 12" or longer wires. You need to be able to connect/disconnect them several times during the process, per the instructions. The length is purely for your convenience so you aren't spending the whole time bent over in funny positions. Unless that's your thing...
Old 04-06-2023, 06:51 PM #8
owens.levi owens.levi is offline
owens.levi is on a distinguished road
This happened to me when I plugged in an off-brand OBD code reader. Or rather when I unplugged it. I just rode around with the codes for awhile because I saw the zero point calibration procedure posted here and just noped right out of it. It ended up getting fixed for free after I had my Bilsteins installed. The technician only noticed the codes after the work was done, and thought it was related to the install, so he did the zero point calibration. I can't imagine it would be very expensive to have done.
owens.levi is offline   Reply With QuoteReply With Quote
Old 04-21-2024, 02:15 AM #9
808runnah 808runnah is offline
808runnah is on a distinguished road
I'm hoping someone can help me resolve this issue with my '07 4runner V6. My vsc/trac lights come on shortly after my car starts moving. I've noticed this happened after I did a trans drain/fill, and the wire jump for the "A/T temp" light - for leveling of the fluid.
I've done the following without any success:
-Replaced gas cap
-Unplugged battery
-zero point calibration multiple times
-replaced brake light switch
-hooked up my OBD reader, but no codes
I'm trying to avoid taking it to the stealership, so hoping someone might have another idea. Thanks
808runnah is offline   Reply With QuoteReply With Quote
cap , check , engine , gas , light
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
VSC TRAC, TRAC OFF, and Check engine light all on. samdajellybeenie14 3rd gen T4Rs 13 02-19-2020 09:36 PM
Check engine light vsc trac & trac off lights come on piptraderfx New Members 5 03-14-2014 07:47 AM
VSC, Trac & engine check light with Rod blown through engine. 4RMac 3rd gen T4Rs 10 05-20-2012 04:42 PM
Check engine light Vsc trac Vsc trac off deadmaggot6 Problems & Warranty Issues 0 10-06-2008 09:44 PM
