Exhaust question
Johns06yota
So the exhaust work I have done currently is stock resonator put upstream from flowmaster 40 muffler downstream. For the exit I have a 45 bent out to the side behind the rear wheel on the passenger side.
My question is what rough estimate would it cost to have pipe tied into the exhaust where it goes over the rear axle to have another 45 side exit on the driver side. Not looking to do anything crazy just regular aluminized steel pipe and to mirror the side exit on the passenger side. I don't have much experience in exhaust work so I don't know what a reasonable amount would be. Any info would be greatly appreciated!
Price would vary wildly due to the labor rate charged at various exhaust shops and where you're located.
You're better off just calling your local muffler shops or riding around to a few to get quotes.
Is there enough room in front of the spare tire? The panhard bar still needs room to cycle. Seems like it would be pretty tight, something you should look at if you haven't already before you start calling shops.
Yeah I didn't really realize that. What from your experience would you consider a reasonable labor rate?
Yeah the plan was to have it dip down similar to the borla system that is no longer available to clear the spare and the panhard bar and then go back up on the driver side for the 45 exit. I took measurements for routing it that way and everything would clear
