04-21-2019, 09:28 PM
4th Gen Brake Upgrade Question
I have done a good amount of research but still have some questions on front brake kits for 4th gens. I have a seized caliper and am looking to do a brake upgrade to potentially avoid this situation in the future as well as have overall better braking performance. I am looking at the Powerstop towing kit on Rockauto.com and wondering if I should get the 4Runner specific one, or if there is any advantage to getting the Tundra one and fitting that for the 4runner. I have a 2006 limited and the 4Runner kit says its a 319mm rotor which I believe is the smaller SR5 rotor size? Any advice or suggestions are welcomed.
4runner Specific Kit: More Information for POWER STOP KC13736
Tundra Kit: More Information for POWER STOP KC232436
"Keep close to Nature’s heart... and break clear away, once in awhile, and climb a mountain or spend a week in the woods. Wash your spirit clean."
04-21-2019, 09:48 PM
Real Name: Leonard
Real Name: Leonard
I just did this 36 kit, stuck with the 319s no calipers as I dont have road condition problem like you creating frozen piston.
I'm a lot heavier and over size tires. They have a better bit, and bit harder as they heat up.
This is compared to factory.
Having fun's build
04-21-2019, 10:18 PM
Real Name: Russell (OB #9908)
I’ve been very happy with the PowerStop Z36 kit on my ‘07 Sport, which has the larger front rotors. While I only needed rotors & pads, I imagine their calipers are good quality as well.
04-22-2019, 12:00 AM
I have the drilled and slotted rotors, Z36 pads and red powder coated calipers on mine, and they are not only awesome looking, but they work WAY better than the original brakes.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
04-22-2019, 10:50 AM
Thanks for the answers! Just ordered the Z36 kit including the calipers from RockAuto
04-22-2019, 12:26 PM
You are just going to use 4th gen parts right? If using 5th gen make sure you stick with 4th gen rotors. The hub diameter is different and will give you problems.
Sent from my SM-G950U using Tapatalk
04-22-2019, 01:15 PM
Correct. I ordered the kit for the 4th gen 4Runner
Thanks!
05-06-2019, 11:59 AM
Ordered my Z36 today!
2008 4wd V6 Limited Xreas - 2.5/1.5 Daystar - 17" TRD Wheels w/ 255/75-17 BFG KO2's - NFAB Steps - Debadged and 5th Gen REbadged - Maplight Mod - Interior LED Swap - LaminX Yellow Fogs - Gobi Stealth - Powerstop Z36 Brakes - Husky Liners - DeWalt Bluetooth Dongle - Blackedout Headlights with LED's
05-06-2019, 12:14 PM
Real Name: Michael
Real Name: Michael
Just clarifying this statement. Only the 5th gen rear rotors cause issue. The fronts work fine.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
05-08-2019, 06:06 PM
Power stop Z36 with big front rotors dropped off at mechanic tonight after work.
Can’t wait.
05-08-2019, 10:37 PM
Can’t wait.
Looking forward to your next update. I’m a big fan of the Z36 kit.
05-09-2019, 04:58 PM
First update:
The brand new front passenger side caliper is defective.
My guy can’t even blow air through it.
RockAuto doesn’t have a customer service line, so I sent an email.
Called PowerStop and they said “sorry”, we won’t do anything to help you. Call Rock Auto. Good luck”.
RockAuto responded that they are going to FEDEX ground ship me a new pair of front calipers. I should receive my tracking number within two business days. I was told that if I wanted it any faster, I could :
Go back online
Cancel the new replacement order.
File for a refund instead.
Order a new pair and pay for expedited shipping.
Wait.
Oof. What a day.
05-09-2019, 05:14 PM
Real Name: Leonard
Real Name: Leonard
First update:
Go back online
Wait.
Oof. What a day.
And supposedly they test the calipers, so much for QC.
Having fun's build
05-13-2019, 07:50 PM
Finally got them installed!
RockAuto sent me a new pair of front calipers to accommodate the front passenger side being defective.
So I’m now sitting on a brand new and working drivers side, and a brand new passenger that needs some “fussing”.
These are part of the red coated, tow rated set.
Anyone interested?
05-13-2019, 08:16 PM
Real Name: Alec
Real Name: Alec
I'll upgrade my Brakes when my V8 gets faster....
Stock Brakes are good enough for bone Stock 4R's
Galactic Mica '04 V8 Sport Edition 4x4 110K+ Miles
Airbox Charcoal Filter Mod, Summit Racing 3 inch Electric Exhaust Cut out
265/70R17 Goodyear A/T's Load Range E, Fumoto Oil Drain Plug
