Please help
Spaul121990
Hey everyone, i need help finding a thread. Looked around and cant find it, im sure this has been talked about.
2003 4Runner limited 4.7L
So when i let go of the break, theres a slight knock under the car. I dont drive it every day (wife car) but i do drive it sometimes and now the knock is harder, and i feel it sometimes after slowing down and resuming to accelerate.
Another problem is the gear shifter needs to get hit in order to go into 4th gear from Drive position.
Can some please send me the links to those two discussions.
Thanks in advance
Thanks in advance
Here's a link to the shifter issue, this topic is what happens after it get passed what you're experiencing and the indent pin pops out of it's hole, but I do believe they talk about how it starts.
https://www.toyota-4runner.org/4th-...-floppy-shifter.html?highlight=floppy+shifter
Here are several topics on the bump/thump/jolt after braking, it is caused by the driveshaft binding up because the slip joint needs to be greased!
https://www.toyota-4runner.org/4th-...oming-stop.html?highlight=thump+after+braking
https://www.toyota-4runner.org/4th-gen-t4rs/73132-driveline-clunk.html?highlight=thump+after+braking
https://www.toyota-4runner.org/4th-...-off-brake.html?highlight=thump+after+braking
https://www.toyota-4runner.org/4th-...haft-issue.html?highlight=thump+after+braking
https://www.toyota-4runner.org/4th-...ler-shafts.html?highlight=thump+after+braking
