Originally Posted by TLChip
Do you happen to have a list of all the oem part numbers for the arm, bushings, and hardware? Planning on taking care of this in the near future.
LCA Driver Side - 48069-60010
LCA Passenger - 48068-60010
Front Cam Adjuster Sleeve - 48409-60020
Front Cam Adjuster Nut - 48452-35020
Front Cam Adjuster Bolt - 90119-14120
Rear Cam Bolt - 48190-60020
Rear Cam Nut - 90179-14069
Rear Cam Plate - 48198-6011
Minus the LCAs themselves, you will need 2 of everything listed above to do both sides. Make sure you get those aforementioned blades, and also don't forget to put anti seize on the new parts going in so that they can be adjusted in the future without freezing up.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
