Ebay LCA Lower control arms
pahaf91
Hey guys. New to this form and thought I will share some LCA experince. I treid to search and couldnt really find to much info about eBay LCA.
I bought the AM Autoparts LCA for $122.59 with free shipping.
I did a bunch of research about removal and installing the LCA while waiting for them to arrive. Lucky me, I only had one seized cam in the front passenger side. Used a grinder and it took 4 min.
About the Ebay lower control arm. It is almost identical to the stock one. Difference i can see is the spray of metal from welding
and this part has a bigger "divot"
Balljoint looks identical as well
other then that, i installed them without any isssues and truck feels nice and tight. I guess we will see how they last.
I've had a 1AAuto LCA on one side on my 03 V8 since August 2017, so far so good, I'm on-road only though.
Before I installed it I pulled the BJ seal to the side and needle greased some more grease in it just in case.
How are they holding up...
Pinging this thread to see how the aftermarket LCAs held up over a long period of time. I need to replace my LCAs and I'm looking at options...
How are your 1AAuto LCAs holding up?
They are doing fine, but before I installed them I replaced the bushings with SuperPro, added grease to the ball joints, painted them and plugged the holes in them with plastic plugs and RTV to keep water out. I don't off road and only put maybe 3K miles on per year, so they live an easy life.
wayblom
