Front recovery points
benztech82
Soooo, my rusted tie down point at rad support literaly exploded when my truck was stuck and buddy was whinching me out of deep mud.
Now i'm in the market for proper recovery points and since i'm on a extremely cheap budget and rusted rad support that i can't replace now. I want to weld 2 recovery points on top of the r-bar behind front bumper cover, right on the top.
https://www.amazon.com/Rugged-Ridge...very+point+rugged+ridge&qid=1573009875&sr=8-4
Did anyone try such setup before?
Sent from my Redmi 4 using Tapatalk
im missing one of those too, looks like it exploded as well. interested in your solution...i might get a bolt on front point sometime. the remaining one on the front and soft shackle i hope can hold work if i need to get recovered until then. i keep hitch shackle in my recover gear as well.
speaking of recovery points, does anyone know if the loop tucked up under the rear, near spare tire is a recovery point?
I have these as well. They are pretty beefy. Got them on sale for like 140 a while back. They bolt into existing threaded locations.
This is nice, but if your rad support is rusty I wouldn't take a chance bolting this there. Mine is 2005 and my rad support can only hold rad in place with that much rust. Also last time my truck was stuck going downhill in mud and that recovery point wasn't accessible, it's tucked too deep.
Its bolted directly to the frame. I dont think the rad support is going to hold up to any recovery points.
Here is where the d-rings stick out from. they might be kind of low especially if you go muddling. Might have to get a little dirty. But for other things it should be easily accessible.
I feel your pain. My towhook pulled off in my hand as the last owner had literally bondo'd it back on....
Cut out basically the entire left side of the support and then rebuilt it with new metal. It's honestly probably stronger now lol
The rest of my frame is solid, but coolant had leaked here for a while and destroyed it. I'd definitely recommend getting something like this done if you can, so that the rest of the support doesn't crumble away. Maybe even replace the entire support if it's too far gone.
BTW - I believe those are OEM tie down points (for shipping), not recovery points. Mi .02
^^This is my understanding as well, both the fronts and the rears are for shipping tie downs, none of mine are rusted other than minor surface rust, but just looking at them and how they are attached and made of I wouldn't trust them as true recovery points, granted if not badly rusted they will work for minor pulling on but for getting a heavy stuck 4TH Gen T4R unstuck I don't think they are strong enough.
I’ve heard that theory and can’t speak to Toyota’s intent, but if those are just tie-down points, they’re the most over engineered examples ever.
That's exactly what i will do, mine also has some "meat" left that I can weld to. Was it a mig welder that you used?
I'm assuming that you have a 4th Gen(?), if so those are for 5th Gen T4Rs and possibly will not work on a 4th Gen, if you don't have a 4th Gen you have posted in the wrong forum section.
And since this is the 4th Gen forum section here's a link to the recovery points for our 4th Gens from the same vendor.
Recovery Point for Toyota Prado 120 Series / Lexus GX470 / 4th Gen 4Runner | BBG4x4 | Buffalo Bayou Garage
I like the 150 series one much better.
Just not feeling these recovery points that are using the radiator support frame no matter what is said. I feel much better with something that is mounted to the main frame of the truck.
Yes, I have 4th Gen 4Runner (2008). I was about to purchase that 120 series model, but then their customer support recommended me this Prado 150 series model since I am planning to get ARB bumper sometimes next year? From what I understand this model will also fit for 4th Gen 4runner.
But you are right, that BBG-RP120 model is better for 4th Gen 4runner and also cheaper .. :)
I agree that the ones for the Prado 150 look to be much better as it looks to have 3 mounting points...BUT the tow weight rating is lower for the 150 than it is for the Prado 120 with only 2 mounting points, for the 150 it states and it's also stamped on the pieces..."Rated to a Working Weight Limit (WWL) of 3250Kg per tow point"...but for the 120 it states and also stamped on the pieces..."Rated to a Working Weight Limit (WWL) of 5000 Kg per tow point"....which is 1750Kg more per tow point than the 150 for a total of 3500Kg if using both tow points!!!
