Front recovery points
I'm installing the Apex Overland recovery points this weekend.
Sent from my SM-G965U using Tapatalk
Easy peasy
Nice set up Kris. Kind of what I want for my 03 4R.
For the 120 series, I see 2 holes for the bolts on the external side of the frame of my 4R but only one in the internal.
Did you had to drill holes in the internal side to insert the bolts and attach nuts?
Can you please give more details of that first plate that protects the radiators?
Thanks K. I am new at this things
Skid plate is RCI
Engine Skid Plate | 03-09 4Runner / GX 470 – RCI Offroad
And
Bumper Filler Plate | 03-09 4Runner / GX 470 – RCI Offroad
Easiest install you will ever do.
These bolt on front recovery points are a 100% bolt on.
No cutting. No Drilling. No welding.
Designed to allow a bow shackle, soft shackle, and even winch hooks to pass through the main eyelet.
Bolting directly to the frame in 4 locations, these recovery points are a much safer option for rigging than the factory tie down loop, which should never be used for towing or recovery of a stuck vehicle.
Allows the factory sway bar to still be used.
A single mount bolt with this recovery point has the sheer strength of just over 20,000 lbs. This recovery point is secured by 4 bolts in total. AKA, super strong and rated for more than most recovery straps and ropes.
Side braces are MIG welded to the main body and the whole assembly is painted safely red for a long lasting and easily identifiable recovery point.
All necessary Grade 8.8 Hardware is included with each set of recovery points.
Here are the instructions for installing
Recovery Point Installation Instruction
I may have to weld front rebar to front frame adapter, just in case 4 studs that hold rebar to frame let go. Pretty happy with how it looks though :)
Sent from my Redmi 4 using Tapatalk
Apex Overland offer great recovery point, but it's tucked too high for my taste, ARB offer a rated recovery point of 8000KG and it's car specific with Left Or Right side, sold per point, too expensive, I like the Treaty Oak recovery point, it comes with class 10.9 hardware.
It appears that Treaty Oaks doesn't offer recovery points for 4th Gens, so doesn't do us in the 4th Gen forum section any good, maybe post this in the 5th Gen forum since they do make them for the 5th Gens.
Has anyone used any of these options with remote resi brackets? Mine are sandwiched between the sway bar mounts. I can't see adding another bracket in there. Some of the flat ones look like they might work but hard to tell.
Thanks
Does apex offer discount codes for t4r members?
If you DM Apex on Instagram or email them Jill will reply immediately. I have these recovery points on my 4th gen and the install was very easy. I haven't used them yet from a recovery standpoint, but it's nice to know and have as backup.
Stupid question, dooes anyone know if the simple (120 series) treaty oak recovery points fit a 3/4 shackle?
A lot of these say don’t use soft shackles, why?isn’t this the future?
I would guess it's because the inside holes aren't chamfered, and instead are hard 90 degree angles, which means they might tear up soft shackles. I'm planning to chamfer the ones I have.
