11-05-2019, 11:12 PM
Front recovery points
Soooo, my rusted tie down point at rad support literaly exploded when my truck was stuck and buddy was whinching me out of deep mud.
Now i'm in the market for proper recovery points and since i'm on a extremely cheap budget and rusted rad support that i can't replace now. I want to weld 2 recovery points on top of the r-bar behind front bumper cover, right on the top.
https://www.amazon.com/Rugged-Ridge-...3009875&sr=8-4
Did anyone try such setup before?
Sent from my Redmi 4 using Tapatalk
11-06-2019, 10:58 AM
im missing one of those too, looks like it exploded as well. interested in your solution...i might get a bolt on front point sometime. the remaining one on the front and soft shackle i hope can hold work if i need to get recovered until then. i keep hitch shackle in my recover gear as well.
speaking of recovery points, does anyone know if the loop tucked up under the rear, near spare tire is a recovery point?
11-06-2019, 11:16 AM
Real Name: Michael
Real Name: Michael
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
11-06-2019, 11:45 AM
Originally Posted by That_Titanium_4RNR
I have these as well. They are pretty beefy. Got them on sale for like 140 a while back. They bolt into existing threaded locations.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
11-06-2019, 03:14 PM
This is nice, but if your rad support is rusty I wouldn't take a chance bolting this there. Mine is 2005 and my rad support can only hold rad in place with that much rust. Also last time my truck was stuck going downhill in mud and that recovery point wasn't accessible, it's tucked too deep.
11-06-2019, 04:36 PM
Its bolted directly to the frame. I dont think the rad support is going to hold up to any recovery points.
Here is where the d-rings stick out from. they might be kind of low especially if you go muddling. Might have to get a little dirty. But for other things it should be easily accessible.
11-06-2019, 06:22 PM
BTW - I believe those are OEM tie down points (for shipping), not recovery points. Mi .02
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
11-07-2019, 09:26 AM
Real Name: Kevin
Real Name: Kevin
I feel your pain. My towhook pulled off in my hand as the last owner had literally bondo'd it back on....
Cut out basically the entire left side of the support and then rebuilt it with new metal. It's honestly probably stronger now lol
The rest of my frame is solid, but coolant had leaked here for a while and destroyed it. I'd definitely recommend getting something like this done if you can, so that the rest of the support doesn't crumble away. Maybe even replace the entire support if it's too far gone.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
11-07-2019, 06:01 PM
Real Name: Skip
Real Name: Skip
^^This is my understanding as well, both the fronts and the rears are for shipping tie downs, none of mine are rusted other than minor surface rust, but just looking at them and how they are attached and made of I wouldn't trust them as true recovery points, granted if not badly rusted they will work for minor pulling on but for getting a heavy stuck 4TH Gen T4R unstuck I don't think they are strong enough.
2004 Limited V8
11-08-2019, 08:51 PM
Real Name: Russell (OB #9908)
I’ve heard that theory and can’t speak to Toyota’s intent, but if those are just tie-down points, they’re the most over engineered examples ever.
11-09-2019, 09:28 PM
That's exactly what i will do, mine also has some "meat" left that I can weld to. Was it a mig welder that you used?
11-11-2019, 08:53 AM
Real Name: Kevin
Real Name: Kevin
Yeah, a buddy of mine has a mig welder and helped me out with it
11-11-2019, 01:14 PM
Just in case anyone is still looking for some front recovery points I've found 2 alternatives
Treaty Oak Offroad
Buffalo Bayou Garage (30% off with coade: BBGBF30) & on Amazon
These look like one possibly took some inspiration from the other design-wise. I have no experience with either, I just wanted to share some options
Shootersanks
-2007 Shadow Mica SE 4Runner
11-22-2019, 12:14 AM
- GL
11-22-2019, 01:35 AM
Real Name: Skip
Real Name: Skip
Originally Posted by gulinx
I'm assuming that you have a 4th Gen(?), if so those are for 5th Gen T4Rs and possibly will not work on a 4th Gen, if you don't have a 4th Gen you have posted in the wrong forum section.
And since this is the 4th Gen forum section here's a link to the recovery points for our 4th Gens from the same vendor.
Recovery Point for Toyota Prado 120 Series / Lexus GX470 / 4th Gen 4Runner | BBG4x4 | Buffalo Bayou Garage
2004 Limited V8
