Old 04-06-2020, 01:51 AM #1
T4R916 T4R916 is offline
T4R916 is on a distinguished road
Winch
Looking for suggestionon a winch....i have a single hoop demello bumper on so looking for something decent. Dont think i need a Warn. I only wheel about 5 times a year at most.
T4R916 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 04:16 AM #2
SHagood's Avatar
SHagood SHagood is offline
SHagood is just really nice SHagood is just really nice SHagood is just really nice SHagood is just really nice
SHagood's Avatar
I'm in the market for a winch as well, which I've narrowed down:
Smittybilt XRC Gen3 9.5K Comp Series Winch with Synthetic Cable - 98695 | 4wheelparts.com
I don't see the reason to have a 12k winch and this is an affordable option.
2008 Urban Runner
MY BUILD THREAD
SHagood is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 05:11 AM #3
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
You may already be aware, If your Demello has its mounting point inside of the bumper, there is limited space allowed for the winch, you may have to factor that into your decision. My 5th gens Shrockworks would fit a low profile Warn or Ramsey, but the Superwinch I bought for several hundred less (which have gone way up in price since then), had the solenoid located on top like you see on most Jeep winches that are located on top of their bumper. I had to relocate the solenoid to a different location. More trouble than its worth for most people. But basically check the measurements of the mounting pad of your bumper and go from there. Maybe see if Demello has an idea for a cheaper option low profile model. I went with a 9500lb, but for my heavy rig, that might not be enough in extreme situations. Good luck!
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 09:12 AM #4
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
But the Warn evo series has probably the best value. 10 year warranty on all components and standard with a wireless remote.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 01:17 PM #5
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I would recommend a warn M series for durability. The M8000 has a removable solenoid pack which can be moved anywhere. The M8000 is affordable and beefy.
Avoid the warn VR series which is their cheap entry level winches that compare to your local hardware store brands.
You get what you pay for, remember that.
Winch line:
Synthetic will be light but can't take the abuse of a steel cable. If you plan on working with logs or long angled pulls then wire cable can't be beat.
For the rare winching needed a synthetic line is safer and lighter. I've seen many a synthetic line snap but I've never seen a cable snap.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 01:45 PM #6
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
Winch line:
the m8000 are legendary. not as easy to find ive noticed though...
id run a warn vr series but do believe the m8000 is really kickass and enough for our 4runners. they say a lot of people overdo it with lb rating with winches and 8-9.5k will work great. the smitty 9.5 has good reviews in the real world, not so much on large review samples on amazon for example.
i might run the 9.5 smitty, you could buy two of them for the cost of 8k vr warn ...one thing that has me going back to idea of warn is that for a winch plate application it isnt something id want to have to drop bumper and reinstall due to reliability.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 02:06 PM #7
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
The smittybilt X2O 10/12k winches fit perfectly in that bumper. The control box mounts to the passenger side and can turn downward to allow you to plug in the controller while not being exposed to rocks and trees. I have the same bumper setup you do and this winch works great.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 12:03 AM #8
any pictures of it mounted on your vehicle?
Old 04-09-2020, 01:02 AM #9
Caldizzle's Avatar
Caldizzle Caldizzle is offline
Real Name: Calvin
Caldizzle will become famous soon enough
Caldizzle's Avatar
Real Name: Calvin
I have the Gen 2 Smittybilt XRC 9500 with the steel cable...my friend just picked one up as well. Seems to be one of the most affordable winches you can get, but that's all I had room for in my budget.
As noted, make sure you have the space to accommodate the winch and control box; look at the dimensions. I have a CBI bumper, my friend has a Relentless Fab one, and the winch fits fine in both of them. I've used mine a few times so the cost has already been justified.
My control box is mounted so that I plug in the controller through the passenger side hi-lift jack access hole (seen in the closeup). My advice is to also get a few shackles, a tree strap, and a snatch block at the minimum to go along with the winch, and watch some instructional videos. Ronny Dahl has some good advice on YouTube.
Winch-20200222_122607-jpg  Winch-20190616_145255-2-jpg
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
Caldizzle is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 03:16 AM #10
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Anyone rockin' that Harbor Freight winch?
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-09-2020, 07:55 AM #11
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Ive heard of people buying a "cheap" winch, (smittybult) because they only wheel a few times a year, but when they needed it, it didnt work....
A winch could save your rig or someone else's rig, save a get a quaility winch, Warn or ComeUp just my .02
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
times , warn , wheel , winch , year
Modifying an universal winch mounting plate for a hidden winch alia176 4th Gen T4Rs 9 09-10-2018 09:44 PM
Anyone make their own hub winch (bush winch)? Looking for a write up Rancho5 3rd gen T4Rs 0 02-28-2018 10:01 AM
Winch access and operation on a 5th Gen with hidden winch 08runnertjb 5th gen T4Rs 10 02-12-2016 12:40 PM
BudBuilt Winch Plate and Engo 10K winch question cmoua 4th Gen T4Rs 6 07-04-2015 11:55 AM
Budbuilt Hidden Winch Plate and Engo 10K Winch Setup cmoua 4th Gen T4Rs 0 07-01-2015 09:22 PM
