Recovery points with ARB Bumper???
RivMan
Anyone have recovery points with an ARB bumper?
The ARB bumper doesn't include any recovery points, and seems to cover the points used by most add-on recovery points.
Does anyone have any recommendations for a front recovery point that's compatible with the ARB?
Thanks
-Rob
This is the front mount on the ARB.
Maybe look at Demelo"s...
Sent from my SM-N950U using Tapatalk
It doesn't look like Demello sells a recovery point, just a full bumper. I already have an ARB bumper, just looking to add some recovery points up front.
-Rob
That's the main reason I went with Shrockworks over ARB. That said, I believe you can buy an add-on recovery point from ARB.
Just confirming that these fit great with the ARB bumper on a 4th Gen.
-Rob
The factory points will rip off if you are being winched out of a mud hole or a hard spot.
In the past I have simply used a tree strap through one of the arb vertical supports and it's ok.
I plan on cutting a 3/4" piece of plate and bolting it straight to the frame then coming out of the arb bumper where I cut a hole.
Did you have to remove the bumper to access and remove the nut from the upper mounting point?
I didn't.
I was able to get the ARB hardware out, and the new hardware in through the larger hole towards the rear of the truck. It's a bit difficult, but not too bad.
-Rob
Hi Rob,
How were you able to get the ARB hardware out of the top most hole? I want to do same, but am concerned that the nut will just spin without having a wrench around it. Also, how did you retrieve the ARB nut from within the frame?
Hi Rob,
My bolt went into a “nut on a stick”. I was able to loosen it and fish the hardware out by its handle. I can post a pic when I get home, but it looks similar to what came with the recovery points.
-Rob
You continue to use the factory recovery points.
Our 4th gens don't have factory recovery points. If you're referring to the little metal rings up front, those are for the purpose of securing to shipping containers when they get shipped over from Japan. Tie down points. I've seen many break when used for recovery.
Thanks
-Rob
Do a search for Bolt on Shackle or Clevis mounts. You will find exactly what you're looking for :attention:
charlesz
