FS: 4th Gen 2008 Toyota 4Runner V6 4WD – 194K – Modified – $25,900 OBO – NorCal
KwonRunner
Member
https://imgur.com/a/pWrUKgw
FS: 4th Gen 2008 Toyota 4Runner V6 4WD – 194K – Modified – $25,900 OBO – NorCal, CA
Finally time to let my 4th gen go.
It's a 2008 Toyota 4Runner V6 4WD with ~194k miles. It's been a California vehicle its entire life, garage kept, and is virtually rust-free. Clean title, currently registered and smog passed.
It's been thoughtfully modified with quality parts over the years. See below for list.
High Level Details:
• ~194k miles
• 4.0L V6 / automatic
• 4WD / A-TRAC / DAC
• California vehicle its entire life
• Garage kept
• Virtually rust-free
• Clean title
• Current CA registration
• Smog passed
• Oil changed yearly
• 285/75R17 tires
• Upgraded suspension and numerous other modifications
• Located in NorCal
Known issue: Occasionally when using 4LO, the VSC/TRAC warning lights will come on. They go away after switching back to 2HI and do not stay on during normal driving. 4WD, A-TRAC and DAC are functional, and this has not affected normal drivability. I'm mentioning it upfront so there are no surprises.
Otherwise, it runs and drives well. I'm not selling because of a mechanical problem. I'm at the point in life where I'm considering consolidating a couple of vehicles.
Asking $25,900 OBO.
Happy to answer questions, provide more details on the build, or send additional photos to anyone seriously interested
Suspension / Chassis
• King 2.5 adjustable shocks front & rear
• King 650# Front Springs
• ICON Uniball upper control arms
• Dobinsons Extreme HD 3" rear coils
• Panhard correction kit
• Extended rear sway-bar end links
• Energy Suspension front bump stops
• Rear bump-stop drop kit
• BPF shock guards
Wheels / Tires
• 5× Traverse HD 17x8.5 ET0 wheels – Block Bronze
• 5× Falken Wildpeak A/T3W LT285/75R17 Load Range E tires
• Spidertrax 1.25" wheel spacers on all four corners
Armor / Recovery
• DeMello Off-Road 3-Hoop front bumper
• DeMello X-Wing rock sliders
• WARN VR8000-S winch with synthetic rope
• RCI full aluminum skid package
• RCI rear differential skid
• MAXTRAX MKII recovery boards
• Krazy Beaver shovel
Custom 4x4 Labs Rear Expedition Setup
• Custom dual-swing rear bumper
• Spare tire carrier
• Accessory tree
• Flip-down table
• Propane tank/mount
• RotopaX mounting
• MAXTRAX mounting
• Custom kicker tubes
• Baja Designs rear lighting
Overland / Camping
• Go Fast Campers GFC SuperLite rooftop tent
• Outgear Solutions rack
• Solid Wood Worx drawer system / Sleeping Platform
• Dometic CFX 75DZW dual-zone fridge/freezer
• Dometic fridge slide
• Rago Fabrication MOLLE storage panels
• RotopaX 2-gallon water, fuel, diesel and storage packs
Air / Electrical / Lighting
• Odyssey Battery, Extreme Series, AGM, 12V, 850 Cranking amps, Secured with the Rago Fabrication battery tie-down
• ARB CKMTA12 Twin onboard air compressor
• ARB Safari Snorkel
• ARB differential breather
• Switch-Pros SP-9100 8-switch power system
• Baja Designs Ditch lights, Fog lights, Rear lights, Chase lights
• Black crystal headlights
• Rago Fabrication Battery Tie-Down
• Rago Fabrication ARB Air Compressor Mount
Interior / Electronics
• Pioneer DMH-W3050NEX touchscreen head unit
Deka
