06-09-2020, 10:36 AM
Swapping in a 2wd steering rack into my 4wd
Hi fellas,
My rack is not leaking but in need of a rebuild so I grabbed one from a 2004 2wd 4Runner with the V8. I didn't check the parts site to see if the part #s match for both vehicles but I don't see a problem with this swap.
Please share your thoughts if you have done this or have knowledge of something I didn't think about.
Thanks.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
06-12-2020, 11:57 AM
Friday bump!!!
06-12-2020, 12:11 PM
Originally Posted by alia176
Friday bump!!!
I have this post saved from facebook: 4th Gen 4Runner Familia Public Group | Facebook
He did a frame swap with a 2wd frame into his 4wd everything. The frames are apparently the same. If he can go 4wd to 2wd frame, I imagine you could go 2wd rack in 4wd frame.
06-16-2020, 07:56 AM
That is EXCELLENT info, thank you sir. I'll go check out the post but I'm already getting warm & fuzzy.
06-16-2020, 09:14 AM
No problem, glad I could share something that helps!
