Originally Posted by MikeinNH67
Usually though, if the compressor is not kicking on in higher temps it's because you are slightly low on refrigerant.
the temp doesn't seem to matter. it's literally if it rains or not. it worked during the winter, I assume because of the snow.
also, I had Firestone run a test of the entire system because I thought it needed refrigerant when I first bought it. they said it was full and that the compressor wasn't turning on all the time. but when it does turn on, it's ice cold and I can see the stuff in the viewing glass just fine.
no blinking light, relay is fine, it just chooses when to turn on. all temps work great when it's on, auto and manual. it's just hit or miss when the compressor turns on.
J.
