Old 08-07-2020, 10:13 AM #1
LA4RUNNERGUY LA4RUNNERGUY is offline
Real Name: Marciano
LA4RUNNERGUY is on a distinguished road
Real Name: Marciano
Front Skid Plate
Hello,
I just purchased an 08 SR5 and while detailing it, I noticed that I may be missing one of the front skid plates since I can clearly see the radiator from underneath. I am not 100% certain since all the images i find on google and in the forums show aftermarket or the silver Toyota one that completely cover the front undercarriage area. If I am missing one, I will search for the OEM one.
Any guidance is appreciated.
thanks,
Marc
Front Skid Plate-4runner-1-jpg  Front Skid Plate-4runner-4-jpg
LA4RUNNERGUY is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:24 AM #2
swampdodo swampdodo is offline
swampdodo has a spectacular aura about swampdodo has a spectacular aura about
Front of 4th gen...you not missing one...should be two...1 starting from the radiator support covering the front diff and then another one behind it covering the oil pan.
swampdodo is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:27 AM #3
Real Name: Marciano
Real Name: Marciano
Thank you. Should there be a rubber piece type splash guard or something covering the exposed area in front of the radiator?
Old 08-07-2020, 10:46 AM #4
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
There are no rubber splash guards to cover the radiator. There are rubber splash guards in the wheel wells, but nothing under the radiator
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:50 AM #5
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
RCI makes a bumper filler plate for that spot if you want more protection.
I went with the filler plate, front skid and trans skid from RCI myself. Great products.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCA’s, 255/75R17 KO2’s, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:54 AM #6
Real Name: Marciano
Real Name: Marciano
Thanks All. I appreciate the responses. After looking further, it appears I may be missing one skid plate that goes behind the front one. I think it's the smaller one for the transmission. I am going for an oil change today at the dealer and should be able find out which one is missing.
Thanks
Old 08-07-2020, 11:41 AM #7
y=mx+b's Avatar
y=mx+b's Avatar
Thanks
There should be 2 metal skids, and then a smaller plastic piece that trails off about 8" behind the oil pan skid. 1st pic doesn't have the plastic, second pic does. For reference, front of the vehicle is at the bottom of both pics, in the first pic they're upside down, second one they're just dropped down from their mounting location.
Old 08-08-2020, 08:07 AM #8
Real Name: Marciano
Real Name: Marciano
thanks for the photos, made it easier to figure this out.
Old 08-09-2020, 03:27 PM #9
Real Name: Marciano
Real Name: Marciano
Again thanks for the responses. The dealer service tech confirmed I have the two skid plates provided in the photo by y=mx+b. Only thing missing is the plastic cover for the oil drain plug and I read it's no big deal if I don't have it. I also crawled underneath and see both skid plates
I guess I am being a total newbie, I would have thought the transmission oil pan should also be protected since it looks like the oil pan cover has the two points towards the rear where it looks like another skid plate would attach and protect the trans oil pan. I guess I am just overthinking this.
Front Skid Plate-img_2046-jpg  Front Skid Plate-img_2047-jpg
Old 08-09-2020, 03:45 PM #10
y=mx+b's Avatar
y=mx+b's Avatar
I also find it odd that there is no transmission skid. If you're worried about it for offroading, then there are bolt on aftermarket options.
RCI trans skid: 03-09 4Runner Transmission Skid Plate – RCI Off Road
victory 4x4 mid skid: 4Runner Mid Skid Plate | 4th & 5th Gen (03+) - Victory 4x4
Old 08-09-2020, 08:33 PM #11
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
You really have to be "rock crawling" to get into the trans.
Its tucked up in the frame.
Will be beating on exhaust before trans.
Factory is a bit of plastic.
Really these OEM "skid plates" are nothing more than gravel deflectors.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 10:47 AM #12
Real Name: Marciano
Real Name: Marciano
Thanks Backoff,
I didn't pay attention to how the transmission pan sits well above the frame. I won't be doing any rock crawling or any off roading as mine is a 2 wheel drive.
I might venture off some dirt roads here and there but that's about it. Good to know I am not missing a plate.
Old 08-10-2020, 02:16 PM #13
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Here is what that extra part of the skid looks like... came across it fooling around in the garage today.
Just a sheet of plastic.
Could DIY make one out af a piece of ABS plastic sheet, if so inclined.
Front Skid Plate-img_9111-jpg  Front Skid Plate-img_9112-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 08-15-2020, 10:09 PM #14
himeeto69 himeeto69 is offline
himeeto69 is on a distinguished road
Hello,
thanks,
Marc
i just bought an 05. I should check to see if mine are still there.
himeeto69 is offline   Reply With QuoteReply With Quote
aftermarket , find , front , images , skid
WTB: 4th gen front skid and filler skid Mtoyotaownr Want to Buy/Trade 1 06-06-2019 01:21 AM
Those with RCI front skid 4racer 3rd gen T4Rs 9 07-22-2017 02:30 AM
FS TRD front skid/RCI TRD Integration skid - Las Vegas tigger For Sale: T4R Items 8 08-23-2016 04:05 PM
Stock front skid brackets for RCI engine skid RiDE 5th gen T4Rs 3 02-25-2016 03:00 PM
Skid row 3 front skid plates cheap! spitvenom For Sale: T4R Items 13 08-21-2012 09:47 AM
