Originally Posted by jlyles
Yea no you're exactly right, it's a used car dealership trying to maximize profits. If it was a toyota dealership they probably would've just fixed it with oem parts and I'd be a happy new owner but I guess that's too much to ask from this other dealer. If I can get them to knock $1000 off I'll probably buy it and immediately drop it off at the shop that found the issue for me.
At this point I don't even want them to "fix" the issue themselves cause I'm sure it'll be with bottom-tier parts.
Yeah I'd start with showing the $1,100 quote and trying to get all that off. If you're able to see if the axles are OEM, then get a Toyota Dealer Quote because it'd be more expensive and work the angle of replacing what is already on there to try and get that amount off. For IDing Toyota OEM axles, I have a bunch of pictures posted in response to this thread on both pages:
CV Joints boots cracked, replace now or wait?
Where in VA? If you're in the Richmond-ish Area, theres an RVA Toyota Trucks facebook page that you could join and someone in there might even be willing to help you replace for less than a shop rate. A few guys there work at shops during the day and might want to pick up something on the side. If you want to go to your shop too, thats no sweat.
Also if you're buying a 4runner, check for rust. I'm sure you've already looked into this, but areas to look are:
- front skid mount under radiator
- fuel tank straps
- frame by cats
- ac drain in passenger wheel well
- fame by rear exhaust
- any frame welds seem to rust first
