Old 09-29-2020, 03:56 PM #61
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by Urbanite View Post
Thanks for the pic, I now see it. Had you not posted this, I would have been looking for some time to come;)
No sweat, I have like a bajillion pics of all my projects. Happy to share!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 06:54 PM #62
maxdef maxdef is offline
maxdef will become famous soon enough
Cleaning the interior crust first
I know there are a few threads on regarding rust treatment, but the one area I'm struggling on is getting the loose flaky chunks out of the frame. My problem areas are the sections just past the front wheels, alongside the first cat. There are quite a few pieces that are larger than any of the frame holes and so I'm not sure how to clean it out. I've been using a magnetic reach tool with grabber component but again some of the pieces are too large to be pulled out, especially from the smaller drain-type holes nearby along the bottom, and its very tedious process overall.
Any advice on how to break that up and remove it so I can proceed with some interior coating?
maxdef is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 07:29 PM #63
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I use a coat hanger with a little hook bent in the end, it will break those pieces up as you pull it out of the frame holes. Like you said though, it's a tedious job, I've spent hours just raking a coat hanger in and out of all the holes and the reward is gobbs of rust!
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 10-04-2023, 09:19 PM #64
Bob22222 Bob22222 is offline
Bob22222 is on a distinguished road
Originally Posted by y=mx+b View Post
Not too difficult, I used a pizza box stuffed behind the frame to prevent stuff from getting on the engine. wheel well is pretty easy since I don't have to worry about it getting on any exterior paint.
Only reason I can't suggest doing the whole frame yet, is that I've only used the Rustoleum Rust Converter product in two different sections and would like to test it for a bit before making an official recommendation. It certainly works well and application is easy, but something more industrial might be out there for doing a whole frame.
Eastwoodcompany.com
Has all the supplies you'll ever need for body and frame repair you'll ever need.
Decent priceing too.
Bob22222 is offline   Reply With QuoteReply With Quote
Old 10-05-2023, 03:12 PM #65
I've also seen some people use a drill-powered auger with a chain attached at the end to break things up but I figured I'd ask here before opening a can of worms and spending more than required.
As the person above mentioned, Eastwood does seem like the way to go- when I have the loose rust cleared out, I will be spraying it down with Internal Frame Coating and then a wider application of Fluid Film.
bad , brace , end , reinforced , side
Can I use rust reform on a small body dent with rust? Nooga_Rock Maintenance/Detailing 3 05-18-2020 02:58 AM
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Rust?!?! DaniFami 3rd gen T4Rs 10 10-18-2012 09:50 AM
Has anyone in the rust belt had luck with a DIY rust inhibitor? MilesRacker 3rd gen T4Rs 5 10-17-2008 02:46 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
