Old 10-14-2020, 05:23 PM #16
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
Originally Posted by Captsolo View Post
never been changed
2005 V6 4runner with 150,000 miles.
WP and Alternator OEM too
never had even 1 check engine lite in 15 years.
bought the tool to check the codes, but never have had to use it.
never had an overheat. never had a coolant leak.
I do change the coolant every 5 to 7 years with the best stuff.
Hope you didn't just Jinx yourself lol
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 07:55 PM #17
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
never been changed
You'll never have to replace your timing belt, because the v6 has a timing chain
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 09:38 PM #18
GoldenGoose GoldenGoose is offline
GoldenGoose is on a distinguished road
I was in a similar situation as you. Just picked up my '03 this summer w/ ~275k miles. I didn't know how long it had been since the timing belt had been changed when I bought it, but everything else seemed to be well-maintained. I put about 1k more miles on it over the summer and it drove like a dream.
Took it to a local mechanic last month that has always done me right, and he figured out it was last changed at 90k miles! He said he'd charge me ~$750 to replace it, so I pulled the trigger on it. I figure it probably would have lasted awhile longer, but...you never know!
tl;dr - 176k miles
'03 Limited 4.7L V8. Came to me with ~275k miles and some dark window tint. So far I've added an ARB front bumper w/ 20" Double Row LED, 3" lift kit, and a new timing belt
GoldenGoose is offline   Reply With QuoteReply With Quote
Old 03-08-2024, 05:57 PM #19
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
200,000 miles and 21 years on the original timing belt.
It is getting changed this May.
Running like a champ for the most part. I don't want to chance the destruction of my motor.
There is no plate/sticker to indicate next change, there never has been.
The Toyota dealership I usually go to says that its original to the car.
Moist is offline   Reply With QuoteReply With Quote
Old 03-09-2024, 02:46 PM #20
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
If you have the owner's service manual you'll see it's a 90,000 mile service. If your belt breaks you'll have a very large paperweight because the V8 is an interference engine, meaning the valves extend into the cylinder. A belt break means the pistons will be hammering those valves. :-(
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 03-09-2024, 06:21 PM #21
Ripper238's Avatar
Ripper238's Avatar
Wow, some real chance takers here. Never let a belt go over 100k.
$1000 belt change or $45,000+ new 4Runner. I'll swap the belt.
Old 03-12-2024, 07:17 PM #22
Moist's Avatar
Moist's Avatar
I got the car at 180 something thousand miles, and have been struggling for money until recently. Toyota can build a good belt. I cant stress this enough though DONT LET IT GET THIS BAD.
there are major oil leaks from the timing cover and I dont think she's going to live much longer. Glad I'm changing it soon
Old 03-13-2024, 11:24 AM #23
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
270k 04 v8
bought it with 268k and no tag or service history of it being done. Worked at Toyota/Lexus dealer at the time. Tech said it was original but didn't look bad. Explained the angles for the routing on the 2uz make them less likely to fail compared to other engines. I had a customer there with 346k on 03 v8 with original belt. Engine failure was caused by his daughter letting a radiator leak go without keeping coolant in it.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
belt , engine , long , replacing , toyota
Replacing timing belt because of AGE at 52,000 miles??? thomasugenius 4th Gen T4Rs 54 03-24-2021 06:14 PM
How long does a timing belt last? peter78 3rd gen T4Rs 27 05-07-2018 06:57 PM
Replacing timing belt/water pump ColoradoMTNlivin 3rd gen T4Rs 8 10-01-2017 09:54 PM
Cam and crank seals when replacing timing belt 808T4R 3rd gen T4Rs 14 05-26-2015 10:12 PM
Replacing Timing belt, is tensioner a must? Draayer 3rd gen T4Rs 7 05-29-2014 07:59 AM
