Old 10-21-2020, 01:20 PM #1
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Calling Evaporator Core Veterans
So I find myself faced with a bad evap core, as confirmed by Toyota. I've gotten several quotes, this job looks to cost about $1k+ in labor in my area.
Toyota Dealer: $2250
Indie Mechanics (had 3 quote, all were the same): $1500
I'm considering tackling it myself, my only concern is it's getting colder in my area and I'd be doing this in an un-heated garage and am worried about breaking brittle electrical connectors. Skill-wise, I'm fairly green but have done XREAS delete and 5100s/spring install on this truck as well as brakes/rotors on multiple vehicles.
Thoughts? Talk me out of it? $1k is a tough pill to swallow.
eleven14 is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 02:54 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I'm in the same boat, my evap core is donzo too. I'm thinking I'll DIY mine and try and grab some pics for a writeup. For the past 2-3 years its been able to hold the refrigerant for a whole year before going out, so my plan is to recharge and limp it to next spring, after plastic breaking season. A while ago, I heard someone mention that most auto repairs "are just a bunch of bolts" and this has given me the confidence to complete more challenging jobs on my own. LCA rebuild is only 5 bolts lol. Obviously there's a tad more to it than that, but as long as you research and have the proper tools, I'd send it.
Here are some relevant links I've collected while researching:
Solo Evap Core Replacement- DONE! Pics and Info by @TheHennDoggg
A/C Evaporator Core Replacement by @jaxX-
4th Gen Evaporator Core Replacement
I'm leaking dye out the AC drain.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 03:19 PM #3
Cezar Cezar is offline
Cezar is on a distinguished road
Same boat. Topped it off for a couple years and finally this fall it stopped holding.
I figured I would get a brand new dash (cracking) and do the heater core and evap. Got some blend door issues too that need addressed at the same time.
Can't decide if it's something I want to do or not. I've done heater cores before, how hard can it be?
Cezar is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 03:23 PM #4
I mean, based on your legendary write-ups, there's no question I could tackle it after you.
Mine held three months after the last recharge, so it's an appreciably larger leak that's accelerated by parking on declines for some reason. So it would be a matter of limping through winter w/o defrost with a discharged system.
Will update this thread with how I proceed, if I pull the trigger on DIY will definitely document my experience.
Old 10-21-2020, 03:46 PM #5
y=mx+b's Avatar
y=mx+b's Avatar
Thanks man, I really appreciate that! That's pretty much the main reasons I like making them, it helps us all to learn more about our 4runners. I'm planning to make one whenever I can get to the evap core, although it may be after you like you mentioned.
oh yeah, your is definitely leaking faster than mine. I always forget that the AC drys our the air for defrost, crap thats kinda important. Hopefully the others will chime in with their experiences. From what I've heard, it sounds more of a pain to remove the dash and time consuming, than difficult/tricky in a problem solving sense.
Appreciate the updates, I'll do some digging too.
Old 10-21-2020, 03:56 PM #6
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
Can someone share the symptoms of the issues?
I have recently noticed that Freon is leaking (the ac is not as cold), it has been recharged and now it seems to slowly leak again. On top of that there is a difference in temperature between passenger and driver vents. Does that match the subject's description?
07 SE V6, Front: Dobinsons LT GS59-220 + C59-302 w/ ICON UCAs;
Rear: GS59-575 + C59-677V w/ ICON Trailing Arms; PCK;
Coastal-Offroad bumper and sliders; ASFIR aluminum skids;
255/80r17 Falken AT3W on Toyota Trail edition wheels;
andreylights is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 04:13 PM #7
y=mx+b's Avatar
y=mx+b's Avatar
With AC on, passenger cold and driver warm usually means low on freon, but there are a few other things that would cause this like the blend doors actuators and another reason that seems to be escaping me right now. I just remember someone had this issue and something strange fixed it, kicking myself I can't remember what it was.
Dye leaking into the A/C drain is one of the big givaways. I have extended my AC drain with clear vinyl tubing, and it was bright green after like 3 days. That is what the picture I have linked above is showing.
Old 10-21-2020, 04:27 PM #8
y=mx+b hit on most of the points but, for mine, the giveaway was the driver's side being warm while passenger side vents remained cool.
After recharging the system (w/ dye, there's no dye in the system from the factory), both sides were equally ice-cold for about three months, at which point the driver's side was again noticeably warmer than the passenger side.
That indicated my blend doors were functioning correctly and dye detection via a/c drain line (and via freon sniffer in the vents) confirmed it's a dead evap core for me.
Good luck and shout if you have more questions.
Old 10-21-2020, 06:05 PM #9
Captsolo Captsolo is offline
Captsolo will become famous soon enough
My evaporator core needs replacing. Denso part at Amazon is $99.
Shop guy told me $300 for installation
I have a 2005 V6 4runner. Lasted 15 years. 4runner runs so great I just can't let it go (150,000 short miles in Nassau Bahamas).
Never had a car that ran so well after 15 years.
Three starters replacements - no big deal.
Amazon.com: Denso 476-0040 A/C Evaporator Core: Automotive
New starter for $91. Two bolts to remove and replace, Wow!
Amazon.com: New Starter Replacement For 2003-2010 Toyota 4Runner FJ Cruiser Tundra Tacoma 03 04 05 06 07 08 09 10 428000-1250 28100-31050 SR3287N: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 06:23 PM #10
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Many starters are secured by two fasteners, this is not novel. And you linked an alternator, not a starter.
triethylborane is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 06:48 PM #11
Let us know how this works out for you but if the outfit is legit and actually understands what's involved, they're losing money on this job.
Old 10-21-2020, 07:28 PM #12
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Keep in mind that if its leaking at the Evaporator, its leaking into the cabin air flow. If you keep recharging the system, you are breathing in 134a continually. I would recommend not using the AC. Its going to cause health issues.
Exposure Guidance Levels for Hydrofluorocarbon-134a - Toxicity of Alternatives to Chlorofluorocarbons - NCBI Bookshelf
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
area , core , green , skill-wise , toyota
2011 bad AC evaporator core? mag4x4 5th gen T4Rs 12 11-24-2023 07:20 PM
A/C Evaporator Core Replacement jaxX- 4th Gen T4Rs 23 05-21-2021 10:39 PM
4th Gen Evaporator Core Replacement TungstenSquash 4th Gen T4Rs 13 10-04-2020 01:24 PM
Evaporator core, doing it myself IOPturbo 4th Gen T4Rs 2 04-16-2014 02:43 PM
Evaporator Core Replacement tuteng 4th Gen T4Rs 0 07-15-2012 04:59 PM
