Old 10-27-2020, 01:58 AM #1
chasrrr chasrrr is offline
chasrrr will become famous soon enough
FOX TRD Suspension on my 07 V6
Yo T4R! Found a set of 2020 4runner trd pro shock Fox 2.5's for a resonable price. Been doing some research and still haven't found any good resources / people doing this. I'm looking to keep my 4Runner ride setup low in terms of height but with improved ride quality. Makes sense that having the foxes with resi's the ride and performance on/off-road will improve like any aftermarket shock with resivoirs would. I'm thinking this setup with slight modification would probably give around 1" of lift with running an extended coil in the rear to level things out. Anyone have thoughts on this? What coils in the rear would you recommend? I've begun trimming (pinch welds, body mount chop, and fender trimming) and am attempting to fit 35's keeping the 4runner as low as possible. SPC uppers on the way to push my castor as far forward as possible as well. Would love to hear thoughts.
Cheers,
Chase
chasrrr is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 06:48 AM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Not sure about it, but I think the coil bucket top hat is the same. The only thing that might bone you is the lower shock mount, but can't confirm that either way.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 09:48 AM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So the coils/ springs on a 5th gen give about a 1in lift to 4th gen and the trd has roughly another inch lift so you’re looking at maybe 2 inches. You’ll have to read through converting 4th gen to 5th gen struts, but yea you’ll need a bigger lower mount hole for the bushing and then you’ll only fit 5th gen struts from there on out
Old 10-27-2020, 11:08 AM #4
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Better get out the big guns!
Can vouch though, Fox 2.5s with resis/DSC is a comfortable, solid suspension.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 11:08 AM #5
montijo505's Avatar
montijo505's Avatar
I believe you also have to grind down either the LCA bucket or the actual lower mount on the strut to squeeze it in there. I would look at some dobinsons rear springs. They have lots of different height options.
Good luck fitting 35's with minimal lift, but don't let me discourage you. You'll need a body lift and aggressive BMC as well as extended rear bump stops. Post results!
Sent from my SM-G986U using Tapatalk
Old 10-27-2020, 07:24 PM #6
Yeah it looks like the top plate on the front struts in actually the same and there is some mods needed to change the lower mount or some people say you can get a different bushing pressed into TRD Fox's. Thatnks for the info on the ride height. I think I'm gonna go for it and see what happens. I'll document the setup in a updated thread once I'm all finished. Cheers dude!
I've got some Rough Country coils sitting in storage I might use for test fitting and then get some Dobinson's ordered once I've got it all mapped out.
You can fit 35's if you're willing to cut. I don't think ride height actually has anything to do with fitting bigger tires. Just maybe makes parts of the process a tad easier. Wish me luck! I'll update when it's all done.
Old 10-29-2020, 11:31 AM #7
alextmullis's Avatar
alextmullis alextmullis is offline
alextmullis will become famous soon enough
Hi chase.
I’m pretty sure they will fit but you would need to potentially grind down the lower eyelet to fit in the LCA mount. Not a big deal
alextmullis is offline   Reply With QuoteReply With Quote
4runner , fox , ride , setup , thoughts
WTB: TRD Pro Rear Suspension Take-Offs (Shocks & Suspension) - Houston, TX steveh_2007 For Sale: Suspension/Wheels/Tires 0 03-06-2020 12:02 PM
Box of new 4th gen suspension parts(Energy Suspension, OME, MOOG) and headunit $35 nytosc For Sale: T4R Items 0 08-06-2019 01:01 PM
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
