Old 04-15-2021, 01:43 PM #16
blakkbox blakkbox is offline
blakkbox is on a distinguished road
Originally Posted by ads2539 View Post
The OME 886 springs sound about right. If I had gone OME, I would have bought the 885, but I don’t have the extra weight of a steel front bumper.
It’s too bad the body lift would be a pain for you.
I don’t know which springs work well with the Bilstein shocks. I have Toytec/Eibach springs, and they seem like a good match to me.
It sounds like your rear suspension is fine.
Just spoke with a local 4x4 shop. They recommend doing the body mount chop and recommended the Toytec 620# springs (112-620-P - Toytec Front Coil Lift Springs). They said the stock spring rate was 500#, so these would be quite a bit stiffer. Are those the same springs you have?
Originally Posted by randy88fj62 View Post
You don't need a welder to do the pinch weld. I did horizontal cuts ever 1.5-2 inches then banged the pieces flat. Once that was done I gooped the area with silicone / RTV. Once dried I painted the area. All you need is a hammer and an angle grinder with a cutoff disk.
Others just slam the weld in with a hammer, no cutting.
If you need some pointers I just did this. pm me and I can facetime to show the end result.
I meant for welding a plate onto the chopped body mounts sorry! Any chance you can post up a pic or two here of your wheel well area after hammering down your pinch weld? Would be happy to see what it looks like once it's been done!
blakkbox is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 02:40 PM #17
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Yes, I have the 112-620-P springs.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 03:44 PM #18
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Easy solution, take off the spidertraxx wheel spacers or cut.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 03:49 PM #19
Interesting, didn't realize this might help... figured they were put on for a reason. Might have to try this out real quick!
Old 04-15-2021, 03:59 PM #20
Inv4drZm's Avatar
Inv4drZm's Avatar
The reason is for looks, but they make the tire swing a larger arc when turning which creates more interference.
Old 04-15-2021, 06:19 PM #21
ads2539's Avatar
ads2539's Avatar
Will a 285 tire rub the UCAs without spacers?
(I have only 255s and 265s.)
Old 04-15-2021, 08:42 PM #22
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
First thing to note is that suspension lifts only clear bigger tires at ride height. As soon as you stuff the tire in the front wheel well, the lift amount doesn't really matter
Second, is that the Caster number itself isn't really a trustworthy measure for the amount of clearance for the tires. As you know, caster is the angle between the line from UBJ to LBJ, and vertical. When lifting the 4runner IFS, while keeping the camber in spec, the caster tends to drop out. This could make keeping the wheels straight on the highway more difficult, wheel not return to center after turns as effectively as stock, etc. JBA UCAs are great for bolt on caster correction back to stock 3* to improve drivability back to stock.
I made a little picture below to try and explain some things better. Background rectangles are reference of LCA mounting positions, and body mount location.
  • The main drawback is that +Caster from the UCA brings the tire backwards in the wheel well, as seen in the first image. While increasing drivability, clearance at the body mount and rear of wheel well is sacrificed. If I remember correctly, you mentioned stock UCAs didn't rub as bad as the JBAs, this is likely why. However, your JBAs will ride better than the stock when lifted due to the increase in caster, and I believe there is more UBJ travel on the JBAs, and the angle is corrected to keep them more centered in that travel.
  • +Caster from the LCA brings the wheel forward. You can set this by adjusting the cam bolts so the front is all of the way in, and the rear is all the way out. The problem with a fixed position UCA, is that this will likely throw off the camber.
  • The capability of adjustable UCAs, like SPCs, allow you to decrease Caster at the UCA, increase Caster at the LCA, and finally adjust the camber into spec. This will result in maximum clearance, with the potential sacrifice of overall caster depending on the tire size. From here, its balancing the tire size with the UCA caster adjustment to get them to fit, while also retaining drivability.
    I'm a fan of adjustable UCAs for this reason, but it doesn't necessarily mean they're the best for your setup. JBAs or other fixed UCAs are great, because you can take to any firestone or wherever, and they only adjust the cams like stock would. Most alignment places would never touch SPCs, and lots of people end up aligning them at home.
The offset of the wheel also plays a role in the fitment. As Inv4drZm mentioned, more negative offset from the spacers increases the scrub radius. More scrub radius can also cause the tire to rub things as the wheels turn left and right. This is also a balance, because the increased backspacing from the spacer will help to space the tire away from the UCA. With JBAs especially, the flat part where the UBJ mounts is fairly wide. Without spacers, it may be tight or contact the UCA, but you'll never know without giving it a shot.
So working with what you have, I'd suggest first removing the spacers and seeing if that helps with the rubbing on the body mount. Check the UCA for rubbing there, as discussed above. If that doesn't work, remount the spacers and evaluate chopping the body mount. (side note: if the spacers were previously loctited, you need to clean all the threads really well and remove all the threadlocker remains before reattaching, or the buildup will cause them to reach torque spec before they're at the desired tightness)
Hopefully that makes sense, always a balancing game when fitting bigger tires on a vehicle that wasn't intended to have any more than a 265/65r17 on there
y=mx+b is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 09:47 PM #23
Inv4drZm's Avatar
Inv4drZm's Avatar
Good point, they probably will with a 4Runner wheel. With the stock 17" sport wheels and 285's my tires rubbed the spindle and couldn't even be mounted.
With OP's FJ wheels he *should* be fine. Factory FJ wheels should space the tire out enough it should clear is my guess.
Old 04-16-2021, 12:28 AM #24
This was my worry.
Interesting. One way to find out! I assume if spacers come off the front they should probably come off the back as well? I might just pull one off on one side of the front to test it out.
Old 04-16-2021, 12:42 AM #25
wow, thanks for the thorough explanation man! You're correct the body mount rub got a little worse with the JBA's. Not a ton, but a little for sure. I would also say the handling on highways / overall responsiveness is better with them. So that adds up per your feedback on them. I wish I would've known this about SPC's before buying the JBAs, sounds like they would have helped but c'est la vie, for now I'll try making the JBAs work. Unless anyone wants to buy them off me here lol.
I'll give taking out the spacers a shot and see what happens, as well as talk with an offroad shop and see what they can do with my alignment. If that doesn't do it, looks like the BMC it is, as well as probably some new front coils for good measure. Are the any aftermarket LCA's that would allow for greater adjustability?
Old 04-16-2021, 01:06 AM #26
y=mx+b's Avatar
y=mx+b's Avatar
No problem, the visual is really helpful for me, so made one to share. Lots of people run JBAs, and they're not necessarily bad. There are a lot of benefits like ease of alignment, just set and forget, BJs less expensive and off-the shelf. They might have even come with some free religious promotional media lol. The tradeoff for these is the UCA caster. Not really a big deal to chop the body mounts, and they can be capped with plates to look clean.
For the spacers, if someone used loctite on them before, make sure to clean it all off the threads before reinstalling and torquing them. Residual hardened locktite will make the bolt reach the torque spec before the studs are to the desired tightness.
Old 04-16-2021, 09:35 AM #27
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I don't think there is any amount of caster adjustment combo you can do with a factory LCA and whatever UCA that will give the clearance needed at the body mount point without having to chop it. Wheel offset , along with the spacers, will only marginally make the issue better or worse judging from my personal setup.
My 33" set up with a 3" lift still required to chop the mount as well as cutting and hammering the pinch weld flat to get the clearance needed while stuffing the tire. I also went ahead and trimmed the fenders when I went the 35" route to get the necessary clearance.
I would recommend verifying the other 2 rubbing points (at the UCA and at full lock on the frame rail near the firewall) as well. This is the biggest rubbing I am getting right now (the frame rail) granted I am on 35's. I don't see a way to fix my frame rail rub unless I went +2 or 3.5" extra track width up front to space the entire wheel out further, but the body mount chop certainly made the clearance significantly better.
aemravan is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 04:09 PM #28
Stopped by another 4x4 shop after work today since I was in the area. They'd never heard of the body mount chop and said they wouldn't do that job, but also recommended trying taking the wheel spacers off. He said he thought the JBAs were less likely to rub than stock, but I'll give that a shot this weekend and see what happens. Also got a recommendation for a good sounding local alignment shop.
May just do the BMC myself, install some springs and take it to the alignment shop. Is there a good thread anywhere about springs that are compatible with the 5100s? Looking for some combo of springs / 5100s height clip setting that'll give me ~2.5" lift with a V8, 120lb steel bumper, and probably a winch in the future. Would those Toytec 620# coils be good or nah? Maybe OME 886s? Advice appreciated.
Old 04-16-2021, 05:44 PM #29
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I plan on pulling my struts out tomorrow and cycling the suspension to see where the wheel will rub.
I'll be doing this with the JBA UCA installed. I will post back monday if I was successful.
Weekend plans:
Install JBA UCAs
Weld on cam tab gussets
Weld on spindle gussets
new inner and outer TREs
Regarding the body mount chop (BMC) you should stop by welding shops. They would be the best suited for the trimming and welding if you dont want to do it yourself. If you were in SoCal I could help you out.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 09:11 PM #30
Johnny4runner's Avatar
Johnny4runner Johnny4runner is offline
Johnny4runner is on a distinguished road
blakkbox covered this above, but make sure the rear alignment cam bolts are maxed out to push the wheels forward. The rear cam lobes should be pointed inwards. With your aftermarket UCAs the alignment shop should be able to get the alignment into spec, or with extra caster. An alignment shop familiar with lifted vehicles should know what to do if you are having clearance issues. I eventually had a BM chop done, but my rubbing was pretty minimal with the alignment like this.
2003 4Runner Sport Edition V6 Galactic Grey
Radflo 2.5, 650#/AllPro 3.5 (f/r), LR UCA, Medic Links, 1" BL, GY Duratrac 285/70/17, Pro Comp 7089 17x8, BM chop
Bumpers: Shrockworks / CBI (f/r)
Other: Hella 700ff w/55w HID conv., BAMF sliders, Engo 10K, 2 x MFC, 48" HiLift, backup light, Galaxy 979 CB & Yaesu FT-7900R
Johnny4runner is offline   Reply With QuoteReply With Quote
body , feedback , front , jba , ucas
Hesitation issues cant solve it andyk5 Classic T4Rs 21 06-08-2018 02:04 AM
Sonoran body mount install issues IsaiahC 3rd gen T4Rs 18 04-14-2017 10:20 AM
Body mount question ( not a body mount chop) crashman 4th Gen T4Rs 1 09-30-2014 01:57 AM
285s With Stock Suspension and a 1" Body Lift spectre6000 3rd gen T4Rs 15 08-05-2012 06:01 PM
Suspension issue and thinking spacers will solve it. Please check in 05 4runner 4th Gen T4Rs 12 01-25-2011 09:51 AM
