Old 08-07-2021, 03:44 PM #16
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by Billynath1988 View Post
The Kendas look great and ive heard great things about them!
Those SPC UCA's your running really help with that extra adjustment. I'm currently running the JBA high caster arms so I will need to figure that out
I just full bumped them without the shocks in, and definitely going to need to chop body mount as I mentioned, hammer the pinch weld, and then trim the front bumper. but the skinniness does help. Might even be able to run them without spacers and still clear my UCAs. Still need to remove some plastic inside the wheel well to see. with JBA they are wider, so may need some spacing
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 04:19 PM #17
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
I run a wheel spacer now with plenty of clearance on the JBA's, but I cant adjust the caster enough to pull the wheel off the body mount. Ive chopped it up pretty good to fit the 285/75's I have, Idk how far I can go before Its an issue.
What's your bump stop setup like? Can you stuff those tires without popping body panels?
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 04:25 PM #18
y=mx+b's Avatar
y=mx+b's Avatar
Stock bump stop. With the wheels straight yes lol. I need to hammer the pinch weld now, so I can't turn any further to see if the edge of the tire catches the flare
With spacers, you tire will have a larger scrub radius, so you may start to hit more things
Old 08-07-2021, 04:31 PM #19
So maybe without spacers, assuming the tall skinnies clear the UCA's, And I believe they will... I might be better on the body mount than with them on?
2005 4Runner SE V8
Old 08-07-2021, 05:07 PM #20
y=mx+b's Avatar
y=mx+b's Avatar
yeo I just beat the pinch weld and full lock stuffed, they don't rub the body mount at all. My body mounts are untouched right now.
I also do have the wheel pushed forward with the rear cam all the way out, front cam all the way in, and SPC setting F, which is almost as far as the tire can be pushed forward. I don't know what the true caster number is, but i've been driving around like this on my baby HT tires without any issues
2021- , a/t , option , ridge , tire
Mickey Thompson ATZ P3 2016 4Runner SR5 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 01-14-2021 02:16 AM
Mickey Thompson Baja STZ wake_rider 3rd gen T4Rs 3 08-28-2014 10:26 PM
Mickey Thompson II C C 3rd gen T4Rs 1 08-24-2012 09:01 AM
FS: 285/75/16 (33's) Mickey Thompson MTZ's ADH8796 Classifieds - buy & sell (no commercial ads please) 0 09-19-2010 05:51 PM
Another tire thread, opinions of Mickey Thompson tires mjfrank Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-06-2007 11:21 AM
