Old 07-26-2021, 08:19 PM #1
judogti judogti is offline
judogti is on a distinguished road
Stumped on shudder while braking still...?
Was wondering what else I should check/change, I am getting some decent shuddering, pulsing, shaking while braking at highway speeds.
I have replaced the front rotors, calipers and pads, rear pads, LCA's (full), shocks are in okay shape. Could it be some other bushings? Shocks?
The car is a 2009 Limited w/ 211,000 miles on it, I dont know what else to look at for replacement to stop the braking shudder.
judogti is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 08:44 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Did the shutter change after installing the new pads and rotors? Did you bed the pads properly? If the pads aren't bedded properly, then at a stop while holding the pads against the hot rotors from braking, they can leave a pad deposit and give a false warped rotor feel
When was the last time the tires were balanced and rotated?
y=mx+b is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 09:34 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You didn't mention replacing the rear rotors or calipers, either or both could be the issue.
2004 Limited V8
Old 07-26-2021, 09:49 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
It’s hard to directly compare experiences by words, but I always experience some significant vibration or feeling the brake clamps tightly, loosens then clamps, possibly like a shudder.
After I replace the pads and rotors, it helps a bit but comes back. Not sure if I always have warped rotors or what cause this for me, but I’ve just become accustomed to it.
Old 07-26-2021, 10:28 PM #5
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
yup bad rear rotor or caliper can cause this and even make you think the problem is something up front
hankd is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 10:57 PM #6
I only did the rear pads, and not the rotors, I can definitely give that a try.
I did properly bed the pads over a tank of gas, but the shudder before and after was pretty much the same.
I did get new tires about 2 months ago with a balance, and had an alignment when I did the LCA's.
I did have a seized caliper so I thought for sure it was that and when that didnt fix the issue, I thought it'd be the bushing on the LCA's.
I appreciate the input and questions.
Old 07-27-2021, 05:14 AM #7
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
If it still noticeable after the rears it could be the ABS. I can feel ABS when I rebuild my brakes on all my older vehicles.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 05:41 PM #8
notajetski notajetski is offline
notajetski is on a distinguished road
Did you change the rotors with the pads, at the same time? Or was there any significant mileage between replacing them?
It's possible that if they were _really_ warped, then the pads might have an unusual contact patch with the rotors, but unlikely. Probably rear brakes and rotors 😅
Other thoughts are maybe to rotate tires and see if that changes anything 🤷*♂️
notajetski is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 06:40 PM #9
Thanks, I'll swap the rear pads and rotors again and if not check the ABS and see if thats it
braking , car , pads , shocks , shudder
Driveline shudder during braking ultimatt 3rd gen T4Rs 13 02-25-2015 08:34 PM
Intermittent Shudder While Braking slimatic 3rd gen T4Rs 7 09-30-2013 11:45 PM
Shudder while braking - after driving a bit. changedsoul 3rd gen T4Rs 9 02-19-2012 03:25 PM
Steering wheel shudder when braking at freeway speeds bju96 3rd gen T4Rs 4 09-09-2009 03:00 AM
Steering wheel shudder when braking - New Brakes Installed kaneman23 General Discussions 6 10-30-2008 08:55 PM
