Old 08-04-2021, 09:44 AM #1
Pekoe1111 Pekoe1111 is offline
Pekoe1111 is on a distinguished road
Will I Damage Anything Driving on Failed Rear Air Suspension?
Last night the rear end of my 2008 4Runner Limited started sagging and bouncing over bumps when driving home. It has XREAS and RAS.
Does it hurt the vehicle driving it for a couple of days until my mechanic can diagnose?
Thanks
Pekoe1111 is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 06:28 PM #2
What would cause both sides of the rear end to drop?
Old 08-04-2021, 06:30 PM #3
Here is what it looks like.
Will I Damage Anything Driving on Failed Rear Air Suspension?-d2b9ce55-8fe0-4fe2-b2e3-16771e549632-jpg
Old 08-04-2021, 06:55 PM #4
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Maybe one rear bad popped or air line broke, causing the rear "springs" (which was the bags) to completely deflate
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 08:54 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Personally I would be more worried about general saftey and getting into an accident more so than hurting the vehicle.
Just drop it off and ask the dealer for a complimentary rental... they almost always oblige.
Old 08-04-2021, 10:46 PM #6
Time to Switch to Coils?
Won’t drive it until it’s looked at by a mechanic, but not going to dealer. Wondering if it’s cost prohibitive to fix air suspension, and perhaps time to switch to coils and shocks (it has XREAS).
Biggest question seems to be what aftermarket solution for lower coil spring mount. Thoughts?
Thanks!
Old 08-06-2021, 12:14 AM #7
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
My understanding is that replacing the rear air is not a big deal (relatively speaking). I think there’s a few threads/vids repairing it on the gx470 (which all had rear air). It could be something simple like an air line is leaking/popped off, sensor is off etc.
XREAS is a different story. It has to be removed at certain detach points and components can be replaced. I believe there is only a small amount of fluid that can spill and still maintain operation - hence the detach points that have one way valves
Disclaimer to the above - this is only what I’ve read have not had to do any of the above myself
Good luck!
Rocket3004 is offline   Reply With QuoteReply With Quote
Old 08-06-2021, 07:34 AM #8
y=mx+b's Avatar
y=mx+b's Avatar
How To: Convert RAS to Coils
X-REAS delete + 2015 Tacoma TRD Offroad install
Old 08-07-2021, 09:37 AM #9
Sportznut Sportznut is offline
Sportznut is on a distinguished road
I had my XReas replaced with Bilstein 5100's about 4 years ago. Good decision.
Sent from my SM-N960U using Tapatalk
2005 White 4Runner Sport - Bilstein 5100's
Sportznut is offline   Reply With QuoteReply With Quote
driving , hurt , ras , rear , xreas
Will I damage my 4Runner by driving without power steering? Pale Rider 4th Gen T4Rs 6 08-22-2019 01:17 PM
Failed smog...barely failed hc and c0 Saint75 So Cal 6 01-13-2014 10:52 PM
Will I damage anything by driving on the spare tire? sandwich 5th gen T4Rs 6 01-24-2012 01:39 AM
Computer failed causing failed inspection!! hallocje 4th Gen T4Rs 3 04-13-2011 01:06 PM
Rear Ended, Hitch Receiver Damage --> Frame Damage? osuchasenuts 3rd gen T4Rs 5 12-01-2010 08:16 PM
