Old 08-04-2021, 09:03 PM #1
theoutbackdream's Avatar
theoutbackdream theoutbackdream is offline
Real Name: Matt
theoutbackdream has a spectacular aura about theoutbackdream has a spectacular aura about
Real Name: Matt
Brake line question + upgrade?
My front brake lines popped while in traffic and the pedal went straight to the floor, so now i'm in need of replacing both my brake lines and pants. It's currently at my friends house so I don't have easy access to it, but I had a few questions...
1. Does anyone know how long the OEM front brake line is? I biked over to Oriley's and they had a centric line, where the rubber hose was 6.5" long and had an overall length of 9". This seems significantly shorter than the OEM one, can anyone confirm? My research finds that the oem one runs 10" long.
2. I've read that the OEM line is good for up to a 3" lift. Is this true? Or should I bite the bullet and go for extended lines?
3. Is SS worth the upgrade for offroading? Getting conflicting info, where it is better, but since you can't see the damage done, it can be quite terrifying.
Thanks!
2007 Limited V6 4WD Build Thread
Find me on Instagram @t4r_explorer
theoutbackdream is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 10:46 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Thanks!
Not sure what suspension you're running up front, but most of the entry level aftermarket suspensions (ex 5100s) don't really extended the front travel much, just change static ride height. So an OEM length line would be fine for that.
They probably want an arm and a leg for the OEM lines, so extended SS lines would probably do the trick fine.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 12:03 AM #3
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
The SS lines are good. You can get stoptech ss lines from Amazon for like $50 prime shipping lol. Pretty cheap and they should last the life of the car.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 04:47 AM #4
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
I do braided SS lines on all my vehicles in lieu of rubber.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 12:59 PM #5
Real Name: Matt
Real Name: Matt
Yea, I'm just running 5100's with OME 886.
Does Stoptech have the center rear lines too? I only found they have the front and rear. Goodridge has a set of 6 for the center rear lines. Might just bite the bullet and get the Goodridge 2-21186
Old 08-05-2021, 01:44 PM #6
montijo505's Avatar
montijo505's Avatar
I installed the goodridge about a year and a half ago, no problems.
Old 08-05-2021, 01:47 PM #7
y=mx+b's Avatar
y=mx+b's Avatar
I would look at extended lines for the rear. Some suspensions like dobinsons offer 12" rear shocks, which need extended rear lines to not hyperextend and destroy the lines
I'm running the apache off road rear lines and stock front lines
Old 08-05-2021, 02:03 PM #8
phatcheeks's Avatar
phatcheeks's Avatar
Not sure. Im running Apache Off-Road extended lines in the rear.
Old 08-05-2021, 09:29 PM #9
I grabbed the centers from Wheeler’s Offroad. Stop Tech only sells the outers through Summit.
brake , line , lines , long , oem
Brake line replacement question I_bRAD 3rd gen T4Rs 20 06-28-2021 08:21 PM
Brake Line Question (OEM vs Aftermarket) ArmArak 3rd gen T4Rs 6 06-17-2020 09:00 PM
2001 SR5 brake line question pink_sleeve 3rd gen T4Rs 0 09-15-2017 06:42 AM
Brake line question vicar 3rd gen T4Rs 2 06-07-2014 05:57 AM
Brake Line Question rickashay 3rd gen T4Rs 0 10-04-2011 11:49 PM
