Old 08-18-2021, 10:06 AM #16
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Originally Posted by Drcoffee View Post
Does the valve allow the thick oil to fully drain from the bottom of the oil pan? Looks to me like the valve threads would stand too tall in the pan stopping all the crud from draining completely. Id be curious, once you drain with the valve, remove the valve and see if anything more drains out.
There are several “threads” on this forum about the length of the fumoto valve threads. After reading those threads, I have concluded that the fumoto valve threads are the proper length. I won’t be doing my first oil change with my fumoto valve until next year, so I won’t know from experience for a while.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 04:22 PM #17
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Originally Posted by weaves View Post
Those are nice, except on some diesels, which can be torqued on there pretty good causes the jaws to dig into the filter and collapse it.
This style works similarly except it uses teeth to grip onto the filter. Hands down the best one I've used.
I like the look of that...where'd you find it. Haven't seen that style before.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 04:28 PM #18
Originally Posted by y=mx+b View Post
I've never used an oil filter wrench on my v6. They don't need to be tightened too the moon, gasket does a fine job with them on there hand tight. A little fresh oil on the gasket helps to prevent them from sticking when removing. I also write the mileage on the filter
For any number of reasons, some folks won't be able to achieve the recommended torque by hand. Even someone with a healthy kung-fu grip will struggle if they get a little oil on their hand or the outside of the can during install.
For similar reasons, I miss the textured coating Purolator used to put on their yellow PureOne filters. More margin of error with oil/sweat/angle of access...or just the finger joints acting up.
Old 08-18-2021, 06:37 PM #19
weaves weaves is offline
weaves is on a distinguished road
Amazon - Amazon.com: ARES 56028 - Universal Oil Filter Wrench - 3/8-Inch Drive - Removes 2.5 to 3.25-inch Diameter Spin-On Style Oil Filters : Automotive
weaves is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 07:53 PM #20
Justbuckstuff Justbuckstuff is offline
Justbuckstuff is on a distinguished road
The last time I had to pull one off a 2UZ I just used a titan strap... granted I was in a hurry and grabbed the first thing I could find that emulated a rubber strap wrench which is my personal favorite for loosening. I could see why the impact mounted one would be nice on the V6 though since its on top.
Justbuckstuff is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 10:12 PM #21
montijo505's Avatar
montijo505's Avatar
I just use a 1/2 drive ratchet to not chance messing anything up.
Old 08-18-2021, 10:21 PM #22
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I write the date & mileage on the filter and everything else I can. Radiator hoses, battery, you name it. Very helpful to have a quick reference right there.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 11:18 PM #23
montijo505's Avatar
montijo505's Avatar
Get a label maker lol
Old 08-19-2021, 11:54 AM #24
Bluesky 07's Avatar
Bluesky 07's Avatar
I have one, it's not worth the bother to make a label for a new oil filter every 6K miles when a Sharpie is right there in the garage. I also have a complete maintenance log in Excel with all the info but being able to see it under the hood is very handy.
Old 08-20-2021, 12:36 PM #25
one other thing i forgot to mention if you have one of the filter wrenches mentioned in the first post that is a tad too big for the filter is to wrap a rag around the filter or a few layers of tape to let the filter grab it better. i just did this on my sisters highlander than had an aftermarket filter on it that was just slightly smaller than the wrench so it would slip before loosening the filter because it was put on too tight... wrapped a rag around the filter & tapped the wrench on & it grabbed enough to get the filter off. i installed it by hand to just under 3/4 turn & should be able to remove it by hand when the time comes.
just wanted to mention that option if anyone is in a bind without the right filter wrench.
Old 08-20-2021, 03:08 PM #26
Urbanite Urbanite is offline
Urbanite is on a distinguished road
That's a good idea, actually that filter cap I showed in 1st post is for a BMW I owned a few years ago and it's 74mm 14 flutes, so wrapping a cloth around it might be the solution for that extra 1mm. I recently got 10 OEM oil filters for $42, reason I asked for wrench size for that filter.
Urbanite is offline   Reply With QuoteReply With Quote
Old 08-20-2021, 08:54 PM #27
triethylborane triethylborane is offline
triethylborane will become famous soon enough
BMW? Must have been an older model, like a 60s or 70s era E3, E9, E12, E23 or some of the early E28s that came with carbureted M30. I dont recall any modern BMWs with spin on filters . . . though my ownership focus is on late 80s and early 90s BMWs.
triethylborane is offline   Reply With QuoteReply With Quote
Old 11-21-2021, 12:31 PM #28
PENOBSCOT PENOBSCOT is offline
PENOBSCOT is on a distinguished road
What is the model/part number of the Fumoto valve you purchased?
PENOBSCOT is offline   Reply With QuoteReply With Quote
Old 11-21-2021, 02:56 PM #29
ads2539's Avatar
ads2539's Avatar
I bought the F103N back in 2017, but I just installed it this year. It’s the version with the long nipple.
On the Fumoto website, they now show the F133N for my 2004. I don’t know what they have changed since 2017, but I do remember reading something about it.
Fumoto shows the same valve for the V6 and the V8 engines. Depending on buyer preference, there are four different valves that fit the 4Runner. I bought the long nipple valve.
Old 11-21-2021, 07:28 PM #30
Thanks for the reply. I am going to add this to the ever growing list for the new to me runner.
filter , oil , size , type , wrench
Oil filter wrench for 5th Gen enolasfinest 5th gen T4Rs 10 04-02-2019 05:05 PM
Oil Filter and Wrench psa5555 Maintenance/Detailing 0 08-13-2013 08:31 PM
Oil Filter Cap Wrench?? Kevin G. 4th Gen T4Rs 14 11-17-2009 04:53 PM
Oil filter wrench/kit? EdmontonOiler 3rd gen T4Rs 4 09-20-2009 04:08 AM
Oil filter wrench for 4th gen V8 4RNR-LOVN Maintenance/Detailing 9 01-18-2005 09:50 AM
