Radio Fuse Keeps Blowing
NWA_Dave
2007 SR5:
I have a newly installed head unit, was working fine for a couple of weeks, installed it with a harness adapter from Crutchfield.
The other day, the Radio 1 fuse (under the hood) blew. I just checked it today, and when I install a new fuse, it blows immediately. It does this when the key is NOT in, so I'm confused...shouldn't there be no power in the circuit when the key is off?
take the radio out and check the harness itself, you might have a chaffed wire. how is it even hooked up, hopefully its crimped and not using wire nuts.
