Old 07-14-2022, 09:26 AM #1
HKTackDriver HKTackDriver is offline
HKTackDriver is on a distinguished road
Rear Hatch Lock Problem - 2007 Limited
Hi all, I went to close my hatch today and instead of the usual motors pulling the hatch closed, it banged down. It looks like the door latch is closed and is banging down on the "hoop" in the floor of the trunk area. Make sense?
Is there any way to open the actuator latch manually? (Or is that not the problem?) Really could use a quick response, my car is sitting in the parking lot outside of my building, unsecured.
2007 Toyota 4Runner Limited V8
HKTackDriver is offline   Reply With QuoteReply With Quote
Old 07-14-2022, 09:40 AM #2
NCrunner2012 NCrunner2012 is offline
NCrunner2012 is on a distinguished road
There is a way to open the door manually but you have to crawl in the back and take off the plastic cover. There are some videos on youtube. Last year the some piece of rubber got wedged in my rear hatch latch and I had to do it. Once I freed it up it worked perfectly again.
How to Manually Release Rear Hatch with Pictures
1998 T4R Limited 4x4- Sold
2005 T4R Limited 4x4 V8
NCrunner2012 is offline   Reply With QuoteReply With Quote
Old 07-14-2022, 09:48 AM #3
Thanks! It's actually open, so I do have access. The problem is it's locked and cannot be closed/latched. Same process that you linked to or is it easier if I have direct access to the actuator?
Old 07-14-2022, 10:34 AM #4
I would say yes, open it up and manually unlock it and you should be able to reset it.
Old 07-14-2022, 10:42 AM #5
Syr4RinNC's Avatar
Syr4RinNC's Avatar
If that doesnt work - take off the plastic cover on the lifegate, spray some WD40 or your favorite lubricant in there and try to clean out anything. can also try disconnecting the battery
Old 07-14-2022, 12:33 PM #6
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Check your battery. Just had to replace mine b/c it was toast and that hatch motor was one of the first things to stop working properly.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 07-15-2022, 07:24 AM #7
That did it! I've done most of that process before when i replaced my hatch Release button, so I flew through it. It's a shame they don't have something else simpler to get that accomplished. Thanks though, that was very helpful!
Old 07-15-2022, 12:28 PM #8
Syr4RinNC's Avatar
Syr4RinNC's Avatar
There are ways to modify it for an escape latch - people have installed levers that they can pull without going through that whole process. I cant find a video right now
- If the actuator isnt working right, sometimes zip tying the levers together can provide it an added boost
Old 07-15-2022, 12:38 PM #9
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Mine's done that a couple of times, just take a screw driver or something and push on the latch and it will reposition and work fine. At least mine did.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
actuator , closed , hatch , latch , problem
Rear hatch won't lock remotely eurasiaoverland 3rd gen T4Rs 4 09-14-2019 02:19 AM
Rear hatch won't lock 37mountainguy 3rd gen T4Rs 11 03-11-2019 05:22 PM
Rear hatch lock Raloy 4th Gen T4Rs 3 12-12-2018 10:49 AM
rear hatch lock olhobbler 3rd gen T4Rs 0 11-26-2013 11:33 AM
Rear Hatch Key lock problem on '99 T4R Rock Slide 3rd gen T4Rs 3 03-27-2006 10:04 AM
