Originally Posted by xtremewlr
I'm not finding the hard lines available from Toyota at all. Your best bet to get them might be to search ebay for some good used ones. Worst case, cut off only as much of the hard line as needed to get solid line and then extend the rubber line. Just make sure whatever you use is rated for trans fluid.
If you saw how many places that the tubes had the grey paint bubbling from rust under the paint you'd understand why I'm uncomfortable using any of the old lines. All of the steel lines that run alongside the engine block need replacing.
Strangely enough, the two steel lines that run from left to right between the radiator and the engine have no rust to speak of.
