Old 10-03-2023, 03:01 PM #1
ace4aday's Avatar
ace4aday ace4aday is offline
ace4aday is on a distinguished road
ace4aday's Avatar
Stubborn CV Axle Help
I've been trying to free my driver's side CV axle from the knuckle for two hours now. I have tried an air hammer (worked well on passenger side), flipping the nut and striking it with a dead blow, using a 5lb mallet with a monster metal spike (bent), using the 5lb mallet with a blocks of wood (destroyed 2x), and spraying it. It hasn't moved at all. I don't think this side has ever been apart. Any other ideas I can try?
2008 Sport V6 in Salsa Red
Ironman 4x4 Stage 2 FCP Lift (2.5"/2")
Vision Manx II Wheels
275-70-17 KO2 Tires
Victory 4x4 Blitz Front Bumper
ace4aday is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 10:22 PM #2
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
You could try a dry-ice or liq.nitrogen to chill and get some expansion and contraction going.
My first thought though was that the hub/knuckle are moving enough when you hit it that it is effectively absorbing the hits. If you can isolate the hub but maybe using a jack to hold the unit more still or blocks between the hub and the frame. Just spitballing ideas.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 11:00 PM #3
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Yeah use bungie cord to support the axle level. Eliminating the angle so all the force is directed in the right direction. Then knock it out.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 12:14 AM #4
ace4aday's Avatar
ace4aday's Avatar
After another hour of banging on it, my hand was struggling to hold the mallet. It didn't budge at all and I had to abort and put it back together for another day. Hopefully my boot holds out a little longer.
Keeping the dry ice idea as a possibility. Hoping some the penetrating spray works its way in over the next few days. I didn't thing about trying the jack to provide resistance. Nothing I tried would stay put. Could help. I didn't understand the strap comment.
I'm wondering if anyone has ever had success with one of these pullers. It says it the big one fits a 5.5" ID.
Stubborn CV Axle Help-71pffu0oitl-_ac_sl1500_-jpg
275-70-17 KO2 Tires
Old 10-04-2023, 11:51 AM #5
d33pt d33pt is offline
d33pt is on a distinguished road
Is it really rusty? Just keep spraying it with good penetration oil (not wd40) and heat it up when you smack it with the hammer.
d33pt is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 12:04 PM #6
ace4aday's Avatar
ace4aday's Avatar
Strangely no. Everything under the dust cap looks beautiful. I sprayed the exposed splines with Ballistol before putting the nut back on. It was the only thing I had. I'll try again this weekend.
275-70-17 KO2 Tires
Old 10-04-2023, 12:22 PM #7
That puller seems like it would work. It will probably let go with a bang. There will be some rust under there for sure. Rust glue.
A little antiseize on the splines will help for next time. A little goes a long way and don't get any on the threads.
Old 10-04-2023, 02:06 PM #8
Bmxer06pa Bmxer06pa is offline
Bmxer06pa is on a distinguished road
maybe if you take the spindle off with the cv still attached you can attack it at a different angle with the spindle secured in a vice or something like that.
Bmxer06pa is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 04:21 PM #9
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
I've never had one that took more than a couple taps with a soft hammer and I live in the rust belt. I think that puller setup is the best idea at this point. Maybe borrow one from your local auto parts store?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-05-2023, 06:51 AM #10
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
I completely ruined an otherwise perfect factory cv axle doing this. All I had to do was swing the entire knuckle up and away and support it with the axle on a relatively flat plane. Get a buddy, a wood block, a floor jack and a ratchet strap to support the assembly. Don’t ruin your axle and force yourself to buy a crap O’reillys cv and spend more money like I did.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 10-05-2023, 10:01 AM #11
ace4aday's Avatar
ace4aday's Avatar
Yours is the second comment calling for a support strap. For clarification, are you suggesting popping the axle from the differential side first?
275-70-17 KO2 Tires
Old 10-05-2023, 05:36 PM #12
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is online now
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
My one experience replacing my driver's side axle convinced me to at least consider having a shop do it next time. Like you, I just couldn't get the SOB to come out. I do a lot of work on my truck but some jobs, like this one, just aren't worth the trouble. This post, especially the video in it, may be helpful.
Bluesky 07 is online now   Reply With QuoteReply With Quote
Old 10-05-2023, 07:12 PM #13
Real Name: Matt
Real Name: Matt
I didn’t have anyone to help me. I used a small block of 4 x 4 to lift the assembly up to flatten the axle and a strap to keep it from rolling front to back. This helped spread the cv’s apart giving it room to grow. When it was all the way down or relaxed even if turned fully with the tie rod off it wouldn’t give anywhere for the outer end of the cv to go. A block of wood on the end and a small two to four Lb sledge should be more than enough. Pop the outer through the unit bearing then pull the inner out of the clamshell. Don’t use a massive sledge and mushroom the splines and threads or destroy the inner bearing. Yeah I did that.
Old 10-05-2023, 09:26 PM #14
Bluesky 07's Avatar
Bluesky 07's Avatar
The seal is what makes me reluctant to do it again. Thought I had it seated, double-checked, and all I got for my trouble was gear oil drops on the garage floor the next morning. Had to pay a shop to replace it.
Old 10-06-2023, 07:13 AM #15
Real Name: Matt
Real Name: Matt
It should be noted that having new seals while in there is a good idea. When I messed my axle up I was removing it to install the ECGS solid bushing and seal. No issues with the seal leaking. The dust cap makes an excellent install tool for the seal behind the knuckle/bearing.
My passenger side inner seal is leaking after 16 years/150,000 miles and it’ll be the first time it’s ever come apart.
5lb , axle , ideas , mallet , side
Trying to remove stubborn #74 bulbs. Am I alone here? Mindomission 3rd gen T4Rs 14 02-01-2016 01:19 PM
stubborn o2 sensor aeb28 4th Gen T4Rs 18 07-24-2015 02:49 PM
HELP! Stubborn rear diff 88Cleve4runner 3rd gen T4Rs 10 07-10-2013 10:59 AM
stubborn dirt newbiemw Maintenance/Detailing 2 05-04-2011 09:43 PM
