Old 11-05-2023, 10:24 AM #1
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
Custom/DIY Armor Thread
Can we start a thread with just custom home made armor, not company made. are armor thread is great but its humongous and most of it is of company DIY kits. can we start one with just the people who have built there own with details.
what size plating or tubing you used, the tools you used. just general info to help the next person that wants to make their own shit or how to save a buck or two on custom stuff you made that helped you with your build.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 11-05-2023, 05:35 PM #2
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
A couple I have built for mine. Currently working on a third lol.
Both bumpers attach to factory threaded holes in the frame with 1/4” plate. All of the round tube you see is 1.75” .120 wall DOM and 1.5” .120 wall DOM tubing (round).
Everything is MIG welded with a Miller 211 using C25 gas and .030 Lincoln wire. I do own a tube bender which is a JD2 model 32 with an electric/hydraulic ram (super nice) as well as a Woodward fab tube notcher.
Other tools to note:
Milwaukee portaband with a Swag offroad table for cutting tube to length and cutting pieces of 1/4” plate, very nice since it’s not as loud as using a grinder with a cut off wheel.
4.5” angle grinder for clean up work or fine tuning tube notches.
Drills, dremel with various bits, milling machine for making big holes if needed.
Tape measure and calipers for measuring.
20 ton press with a Swag Offroad press brake for bending plate, full dimple die set too as my second bumper has 16 gauge steel dimpled plate on it.
I also own a Hypertherm power max 30 plasma cutter and Lincoln Square wave TIG welder but those weren’t used to make these bumpers.
I think this is the gist of it, probably close to 10k in tooling in my garage to be able to do this kind of stuff. That being said though, I didn’t always have all these nice tools. I started out with a $200 welder off Craigslist and a 4” angle grinder and I was making bumpers and sliders out of box tubing with just those. You could also make your own plate bumpers with a grinder and a welder.
I’m a big fan of CAD when building stuff, cardboard aided design. I’m not at a point where I have a 3D scanner to do legit CAD work on the computer but that’s just the next level up!
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
Old 11-06-2023, 09:25 AM #3
ya i'm slowly building the arsenal. luckily my dad did woodwork years ago so its a matter of changing to metal cutting blades. here at 41, regret not taking reins of the machine shop he had when i was a kid. could have been a master at creating stuff by now.
i was heavily looking at the woodward fab bender and the replicas but i'm waiting to see what direction my welding endeavor takes me. those dies get expensive.
both bumpers look amazing, and were the style i was looking at when i'm ready to build, except i want a swingout. have been searching for an argon tank locally waiting for a good deal so once i find that i can start practicing with scrap.
did you basically remove the stock hitch, and rebuild it into the new bumper??
probably closer to the beginning of the year, i'll yank the bumper off and start making a template to bring to life.
Old 11-06-2023, 11:47 AM #4
Cheaper benders certainly work fine too but may take a bit more effort to bend tubing. I am actually planning on adding a swing out to the version 3 bumper. The nice thing about building stuff yourself is a lot of companies sell DIY parts already. Want a hitch? Buy a bare metal DIY hitch off Amazon for $15 and weld it to your brackets. Want a swing out tire carrier? Buy a locking hinge for $150 and a latch for $50 and weld it to your parts and pieces. Both bumpers I built started from this hitch, everything else on the bumpers were custom cut, formed and welded by me.
https://a.co/d/ai3W6z7
Also for welding gas, if you are TIG welding you'll want Argon. If you are MIG welding, you'll want C25 gas (Argon CO2 mix).
Old 11-06-2023, 02:54 PM #5
wicket27's Avatar
wicket27 wicket27 is offline
wicket27 is on a distinguished road
wicket27's Avatar
Custom/DIY Armor Thread-img_8192-jpg
Custom/DIY Armor Thread-img_8068-jpg
Built a high clearance bumper for my 03, was scraping the oem one a bit. Need to take some updated photos with supports and larger tires. No plans for a winch and wanted something light while keeping a semi stock look in the front
wicket27 is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 06:56 AM #6
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
20200104_114950
I built this a few years back out of DOM tubing and some cheaper plate steel. Held up fine for many years! I had a basic MIG welder and metal blade chop saw.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 07:46 PM #7
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
DIY’d my own skid plates. Most of my designs were loosely based off the diy skid plates that member @y=mx+b made and generous enough to share his notes with me.
Main engine skid made from 1/4” plate. Used some 1.25” wide c-channel for the core support bracket. Built stand-offs from 2x2 1/8” wall tube at the front crossmember and made some small stand off spacers for the rear crossmember from 1/2” UHMW plastic.
Made the transmission skid from 3/16” plate.
Used some 1x2 rec tubing for the crossmember stand-off.
Still working on the t-case skid here and there.
Borrowed a buddies plasma cutter, used numerous 4.5” cut off wheels and my trusty old Lincoln Weld-pak booger welder.
Custom/DIY Armor Thread-img_3123-jpg  Custom/DIY Armor Thread-img_3125-jpg
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 12:02 PM #8
Gmutoagrsv Gmutoagrsv is offline
Gmutoagrsv is on a distinguished road
I hope this thread takes off. Definitely great idea for a thread. Looking forward to seeing what everyone is doing the first two rear bumpers are right up my alley. Definitely dig it great to have ideas on what I wanna do.
Gmutoagrsv is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 12:58 PM #9
definitely agree, i mean the armor thread is great but alot of it is for DIY kits from companies, wanted to have a record of custom build by your local garage mechanic DIY person.
i'm a couple months away from actually building mine, i have the welder, i have the cutoff wheels, trying to save for an argon bottle and i can start messing around. i seat here during breakfast and look up ideas and videos almost every day so anxious and excited to start my own builds.
so hard deciding which direction to go because both front plate and hybrid bumpers look amazing on our rides. same thing for the rear, i'm liking the hidden swing arms that come out of the stock bumper than the whole metal bumper itself so...... decisions decisions....
Old 11-21-2023, 06:49 AM #10
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
4yrs ago this was the first version of my Prerunner style bumper when the 4Runner still had the stock length suspension. This was built using pictures as a guide by Apex Fabrication, Merritt Island, Fl.
Custom/DIY Armor Thread-img_4452-copy-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 06:57 AM #11
Real Name: Brett
Real Name: Brett
Now I have a Dirt King +3.5 LT front suspension, so I decided to give the fabrication and welding a try myself, and extended the main tube to match the fiberglass last month. I also wanted to fill in the center section a little, so I added a nerf bar w upright supports and a larger aluminum plate.
Custom/DIY Armor Thread-20231101_150320-jpg  Custom/DIY Armor Thread-20231101_150301-jpg  Custom/DIY Armor Thread-20231027_123003-jpg  Custom/DIY Armor Thread-20231101_135634-jpg  Custom/DIY Armor Thread-20231102_083829-jpg  Custom/DIY Armor Thread-20231104_181802-copy-jpg  Custom/DIY Armor Thread-20231104_181947-copy-jpg
Old 01-19-2024, 11:38 AM #12
Got a good deal on a 75/25 argon bottle, so hopefully some fabrication will start soon. Waiting for my electrician now to throw the outlet for the welder.
Old 04-04-2024, 10:23 AM #13
and the brainstorming begins.........
i like the style of the coastal and relentless bumpers, but i also like the look of the hybrid bumper, so most likely going to be mainly a plate bumper.
anyone have a good starting point as to what size steel plate i should get, to be able to create a whole bumer out of it???
armor , custom , made , start , thread
Show off your custom armor! Jayjayb96 3rd gen T4Rs 15 11-12-2016 12:59 AM
Armor All Custom Shield - Private Labeled Plasti-dip? DexTech General Discussions 2 06-11-2013 02:06 PM
NEW 4th Gen Armor & Custom Fab Company Mtn.Runner 4th Gen T4Rs 56 05-16-2013 09:20 PM
