Old 02-14-2024, 11:07 PM #1
Farmgirl007 Farmgirl007 is offline
Farmgirl007 is on a distinguished road
Removing bad v8 2UZFE vvti and have a few questions
Bought an 08 limited with a known bad engine. Presently have most of wiring connections, main harness to ecu, rad, fan clutch off. Ready to split transmission from motor. Looking for a sticky or procedure on engine removal. Thanks
Farmgirl007 is offline   Reply With QuoteReply With Quote
Old 02-15-2024, 09:55 AM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Good Morning and Welcome. Not surprising, but there is definitely a lack of removal info out there. This video is done with a LC, but the engine is the same. There may be some old forum or social media posts somewhere.... Good Luck!
https://www.youtube.com/watch?v=Ork1ylSryas
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 02-16-2024, 11:22 AM #3
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
I agree with aquasport, there isn't a huge pool of resources out there, and even fewer where it's all compiled into one spot. I didn't do a full write up on the removal, and I have the v6, but maybe my engine swap can give a little insight. Posts #4-5 are the prep and removal. Feel free to reach out with any questions you have, and good luck!
07 Engine Swap into an 03
And here is a semi-complete list of steps I could think of off the top of my head, but don't take it as 100%:
Drain and remove radiator
Disassemble all air intake hoses + fuel lines
Remove fan and fan shroud
Remove serpentine belt
Unbolt starter + bell housing
Unbolt power steering pump
Unbolt ac compressor + lines
Remove starter
Unbolt flywheel
Unbolt + remove exhaust manifolds
Disconnect all plugs and lines (like coolant lines and transmission line brackets)
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 12:58 PM #4
Yes, I watched his video and definitely helpful. Obvious to me these engines don’t go down too often.
Thanks for your response.
Old 02-17-2024, 01:09 PM #5
Thanks P_nlsn. I’ll take a look at your v6 swap. Shouldn’t be that many differences.
Old 02-17-2024, 01:11 PM #6
Mudtoy Mudtoy is offline
Mudtoy is on a distinguished road
Having removed the transmission from several over the years, I have found that the proper tools will make this happen a lot easier. Same principal, just that you are removing the engine.
I bought them from Snap-On but you can improvise...
1/2 on the ratchet end and 3/8 on the socket end, extensions in 6" 12" 24" and 36" versions. also impact wobbler sockets in 10, 12, 14, 17, and 19mm.
A long handle 1/2 ratchet to break free the bell housing and torque converter bolts is way more effective than an impact wrench.
Mudtoy is offline   Reply With QuoteReply With Quote
bad , engine , rad , removing , split
WTB: 05' V8 2UZFE Air Intake Housing Rus.K Want to Buy/Trade 0 01-08-2021 12:40 PM
V8 non vvti swap to v8 vvti? royal T4R 4th Gen T4Rs 8 10-14-2020 04:27 PM
Best 2UZFE Timing Belt Kit BOFFROAD 4th Gen T4Rs 35 05-08-2019 10:20 AM
4.7L V8 Supercharger (VVTI and non-VVTI Engine) blink 4th Gen T4Rs 53 02-17-2019 11:12 AM
2UZFE ?? 4.7 v8 lunchindabox 4th Gen T4Rs 8 06-13-2013 10:27 AM
