05-24-2024, 09:55 AM
![locked up's Avatar](https://www.toyota-4runner.org/customavatars/avatar99447_1.gif) |
V8 Rear Main Seal Job
Rear main seal on my 2003 V8 is leaking.
Local shop quoted it out and listed 3 parts. A torque convertor seal, rear main seal & and O ring ... but didn't give me part #s.
Are these the right parts #'s for my V8 and is there anything else to be done "while I'm in there"?
Toyota 90311-38083 Seal, Oil
90311-38083 Genuine Toyota Seal, Oil)
Toyota 90311-95012 Seal, Engine Rear Oil
90311-95012 - Toyota Parts Deal
Toyota 96721-24025 Ring, O
96721-24025 - Toyota Parts Deal
Picture because we all like pictures...
05-24-2024, 07:58 PM
![Drcoffee's Avatar](https://www.toyota-4runner.org/customavatars/avatar78997_1.gif) |
AT-205. $15 advanced auto parts or Amazon
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
05-25-2024, 09:50 AM
I know some people have success with that, even if only temporary, but it has to have 4WD actuator done anyway. So I'd prefer to replace the seals while it's all apart.
05-25-2024, 09:58 AM
I have the v6 and not familiar with the v8 but isnt the v8 full time 4wd? Which actuator?
05-27-2024, 05:15 PM
It is full time but there is an actuator for 4Hi to 4Lo
05-27-2024, 09:56 PM
![4RunnerAquasport's Avatar](https://www.toyota-4runner.org/customavatars/avatar119302_1.gif) |
Real Name: Brett
Real Name: Brett
Well, some would say it's a good time to do an FJ transfer case swap. Expensive, but worth it imo. Electronic actuators can be problematic.
![](https://www.toyota-4runner.org/signaturepics/sigpic119302_6.gif)
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
05-28-2024, 01:06 PM
I have thought about that also, but in one of the videos I watched I think there was something about the front diff needing to be changed.
I'm not sure if this is correct or not but...
https://youtu.be/HvU0UnXZ3io?si=5-YOqS47aj5G9PfM&t=263
So would not having the ADD front diff cause an issue to the FJ case?
05-31-2024, 05:32 AM
Real Name: Brett
Real Name: Brett
Originally Posted by locked up
There are a couple threads where this is discussed, but I don't have time to find them. I have well over 5k miles on my swap.
No issues.
@ xtremewlr
has many more miles on his and is the guy who researched the possible problems with the T-case, and found it to be false that damage would be incurred using the full time front diff.
05-31-2024, 01:08 PM
![xtremewlr's Avatar](https://www.toyota-4runner.org/customavatars/avatar459231_10.gif) |
Real Name: Todd
Real Name: Todd
No issues.
@ xtremewlr
Yup. I have around 54,000 miles on my swap using the OEM 4WD front axle that is already in the 4Runner. The only issue I have had is having to replace the input shaft seal on the transfer case somewhere around 20k miles ago. My transfer case had 131k miles on it when I installed it, so that wasn't really a surprise.
Unfortunately, a lot of false information was spread by a now defunct company out of California because the owner was a crook. The FJ tcase does fine because it has an internal oil pump already, so the 4Runner front axle can be left in place and you can drive in 2wd without fear.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
05-31-2024, 04:34 PM
![LOSTR4's Avatar](https://www.toyota-4runner.org/customavatars/avatar91425_1.gif) |
Yeeeeeehaw! That is a freakin' awesome to hear! Thank you both for the confirmations and clarifications!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
05-31-2024, 07:02 PM
Real Name: Brett
Real Name: Brett
You can source these t cases from FJs obviously, but the 5th gen 4Runner has the same manual case. Mine is out of a 2012 SR5 4Runner.
06-07-2024, 05:23 PM
Well this changes things for me!
06-07-2024, 05:49 PM
VERY good to know!
I was wondering what my search on Car-Part.com for FJ cases was showing some 4 Runners.
Linking to another thread with some more info on those 5th Gen t-cases so I know where to find it:
VF4B Transfer Case Swap
So I am guessing what I want is the VF2A case. Right?
06-08-2024, 06:38 AM
Real Name: Brett
Real Name: Brett
VERY good to know!
I haven't researched this in awhile, but the link you posted seems to be pretty close as far as applications. I think one of the other cases is for the SR5 with the part time electronic dial actuator, with no center diff lock. The other is the electronic dial actuator full time 4wd WITH the center diff lock, and you are correct about the VF2A being the manual J-shift. This is the case I did my swap with. I found a page in my 5th gen repair manual that confirms this is the manual shift case.
06-11-2024, 09:34 AM
If your mechanic is going to take the Tcase apart in order to replace the three O rings for the actuator box, that should've showed up in your quote.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
