NJrunner11
yes they now make an "easier" lift that only uses top spacers rather than both, however you can still get the old setup. the new "easier" setup is 10 dollars more... below is a copy of the email i sent and the reply i got
We are still using the front setup that has a preload spacer and separate
top spacer, we find that works better than running all top spacer. We are
happy to get you the kit from Daystar that has the new style spacer that
doesn't require strut disassembly if you want, I believe it's about 10.00
more for the kit.
Our kit has the front and rear spacer kits, that is all that is needed to
lift the truck.
Let me know if you need more info.
Thanks,
Wheeler's
-----Original Message-----
From: Michael Hickman Jr [mailto:[email protected]]
Sent: Tuesday, October 14, 2008 3:14 PM
To: [email protected]
Subject: question about daystar 2.5" lift for 2004 Toyota 4runner
The ad on your page shows the daystar 2.5" front and 2.0" back lift selling
for 150$. The picture also shows that the front lift has the preload and
topout spacers. Is this correct? From what ive been reading on forums and
from a few other people that the new daystar lift only uses the topout
spacer in the front as a sort of "easy install". Im not sure if your picture
is old, or these people are wrong, but id like to confirm everything that is
included in the lift and also confirm the price of 150$ for the front and
back lift. THANKS!
in reference to: http://www.wheelersoffroad.com/03up4rundstrlift.htm
more for the kit.
lift the truck.
Thanks,
Wheeler's
back lift. THANKS!
