Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 08-15-2009, 10:05 PM #1
leftyguns21's Avatar
leftyguns21 leftyguns21 is offline
Real Name: Chris
leftyguns21 will become famous soon enough
Real Name: Chris
another blacked out headlight thread...DIY lots of pics.
i know this has been done many times before but questions always come up about the taking it apart so ill do my best to help and provide pics.
i used a semi gloss plastic spray from Lowes and only did the one coat. i did not sand the inside and it stuck nicely and smooth
i did not remove the bumper and you wont need to either.
you will first need to remove this black protective cover, there are several caps holding it in and a small flat blade will do the job
now there are 4 bolts holding the headlights on 3 easy to get to one PITA to get to
to remove the 4th without taking the bumper off...i un-did the bottom screws [2 on drivers side 3 on passenger side] to the fender well and i did the first two on the inside of the tire. there is enough room to get a socet in there barely. the drivers side was the more difficult side. i did not put this bolt back when i put it all back together
the bottom panel of the headlight does latch in into the fender so be carefeul here. after the headlight is removed there is a tab to pop this off
after that just unplug everything and remove headlight.
i had to be careful of my HID bulbs
next there are 5 screws, philip heads, on the back of the headlight assembly
then in the oven at 250 degrees for 8-10 mins. here i had small issue due to my 3M clear mask on the headlight..it did get a little soft but did not get ruined.
slowly pry it apart. i happened to have a gasket scraper like screw driver laying around which had a bigger head on it. this takes some time and i even placed it back in the oven a few times during this process to keep the silicone goop soft
i masked off the corner lamps at first and sprayed them last so that they would not be as dark and i removed the amber reflector. this popped out and i used the dremmel to clean it up some
and thats it. i put it all back together..and put it back in the oven for another 8 mins and pushed it all back together slowly. overall time about 2-3hrs. i didnt actually keep track of the time because i was doing other tasks at the same time.
leftyguns21 is offline   Reply With QuoteReply With Quote
Old 08-15-2009, 10:07 PM #2
Real Name: Chris
Real Name: Chris
here are pics of the lights installed
Old 08-15-2009, 10:12 PM #3
JAC's Avatar
JAC JAC is offline
JAC is on a distinguished road
JAC JAC is offline
JAC's Avatar
Great Job!!!....I know.... those screws behind the bumper are a pain in the a$$$.. I didn't put them back neither...had a hard time taking them off..especially the one from the drivers side when I changed my headlights.
Now we need to see some pics of you blacked out headlights.
2004 -SR5 V6 2WD-Gold-
Front Adjustable Bilsteins Shocks/1.5 DS Backspacers,265/70/17 Firestone Destination A/T's,Eclipse AVN6000 Navi HU,Python Remote Start/Alarm,Wet Okole Seat Covers,Steelcraft Bullbar,Go Rhino HitchStep ...and more
JAC is offline   Reply With QuoteReply With Quote
Old 08-15-2009, 10:15 PM #4
K.C. K.C. is offline
K.C. is on a distinguished road
I actually prefer your stock headlights...however, it was cleanly done.
You're one definately one of thee members on this forum that pays attention to details.
. -Kenny- (formerly icantsee) .
**SOLD** 2007 Toyota 4Runner V6 SR5 4WD - Titanium Metallic
Daystar Spacer Lift 2.5/1.5 (Preload/Topout)|P265/70R17 Bridgestone Dueler A/T Revos|XenonDepot H11 4300k Xtreme HID Kit|Weathertech Floor & Cargo Liners|Rear Axle Diff Breather Extension|Color Matching Grill|Debadged Emblems|FatCat6|Soon/Wishlist|CB Radio|BL 1"|Demello Bolt On Sliders|Icons or Radflo|BajaRack or Rola Rack
K.C. is offline   Reply With QuoteReply With Quote
Old 08-15-2009, 10:16 PM #5
JAC's Avatar
JAC JAC is offline
JAC JAC is offline
JAC's Avatar
Woww...they look sweet!
Old 08-15-2009, 10:38 PM #6
Real Name: Chris
Real Name: Chris
thanks, i appreciate that.
i like the stock too, and was not sure what i wanted more soooo....
once i get an idea in my head i run with it.
thanks JAC, yes the drivers side was a pain but now that i know how to do it ill be able to change it out easy
Old 08-15-2009, 10:50 PM #7
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Boy that didn't take long for you to make up your mind! Nicely done man. Makes such a difference IMHO. You're gonna love it.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 08-15-2009, 10:54 PM #8
Real Name: Chris
Real Name: Chris
yes, i needed something to do today and this seemed like a good project.
thanks again for the info.
Old 08-16-2009, 01:35 AM #9
Bowtie3's Avatar
Bowtie3 Bowtie3 is offline
Bowtie3 is an unknown quantity at this point
Bowtie3's Avatar
Nice write up! I put my lights in the oven at 305 for 9-10 min. But i put them on a baking sheet with card board on it. Seems to work with the first shot. Looks good!!!
I also put some silicone on the tracks of the housing before i put them in the oven again to make sure there is a tight seal. Call me anal but so far all is good.
http://desertfab.com/
http://www.arizonatoyz.com/
Bowtie3 is offline   Reply With QuoteReply With Quote
Old 08-16-2009, 01:44 AM #10
Slvr RnR's Avatar
Slvr RnR Slvr RnR is offline
Slvr RnR is on a distinguished road
Slvr RnR's Avatar
Damn you Leftyguns21! I just convinced myself not to do this mod last week and now you have me thinking about it again. The great thing about it is that it's so cheap and simple to do. I even purchased the paint last weekend.
I just don't know how it would look on my Titanium Metallic with a chrome bull bar and black cover PIAA 520's.
Excellent pics to go with the wright-up.
2007 SR5 V8 4X4 Titanium Metallic
...with a few mods.
Slvr RnR is offline   Reply With QuoteReply With Quote
Old 08-16-2009, 03:22 AM #11
v8 4wd's Avatar
v8 4wd v8 4wd is offline
v8 4wd is on a distinguished road
v8 4wd's Avatar
Thumbs up
ive been deciding back n fourth to do this mod, ive done it on my civic many times but black seems to be too dark imo.... maybe a lighter color will do the trick? perhaps a gunmetal color paint? nonetheless nice work..
v8 4wd is offline   Reply With QuoteReply With Quote
Old 08-16-2009, 03:57 AM #12
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
u didnt mod the squirrel finder when the whole thing was apart? i took the plates out and taped the hole and i got a better cutoff. well nice job, u should of sand and do couple of thin coats, the out come is much better.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-16-2009, 04:03 AM #13
kdub627's Avatar
kdub627 kdub627 is offline
kdub627 is an unknown quantity at this point
kdub627's Avatar
Damn now I gotta do it
kdub627 is offline   Reply With QuoteReply With Quote
Old 08-16-2009, 12:54 PM #14
Real Name: Chris
Real Name: Chris
I didn't have my computer on to look that up when I remembered about the squirrel finder. They don't really bother me much and I don't drive at night a lot so maybe I'll get to that later. Taking the headlights off now is easy.
As far as other colors I say go for it. A gunmetal or even the same body color would look good. I think some sort of an accent color wouldn't look good though.
There's a few other members w silver 4runners and a light bar that have this done I'm pretty sure? I think it would match ok. I had the same mentality it's super cheap and easy to do. It's only headlights so later on if you don't like it you can get new headlights.
Old 08-16-2009, 02:32 PM #15
ecrew16's Avatar
ecrew16 ecrew16 is offline
ecrew16 is an unknown quantity at this point
ecrew16's Avatar
Nice work, that 4th screw way down in the well on the lamp fixture arm really is a pain if you don't do anything out of the ordinary to access it. Look good man!
2006 Black T4R Sport.
Car Domain: http://www.cardomain.com/ride/3846903/1
ecrew16 is offline   Reply With QuoteReply With Quote
