Anyone using Thule Sidearms with the factory roof rack?
2003Can4runner
I just ordered a couple off Amazon and was wondering if I'm going to have any trouble attaching it to the factory rack. Everything I've researched says I should be OK, but wanted to hear from 4runner owners specifically.
Thanks!
No issues...it was a pain to convert one sidearm
to be the passenger side one, but they work with the factory rack no problem...good luck...
Thank for the reply.
What made it difficult putting it on the passenger side? Is it because you wanted that one facing the other way? Sorry if I'm missing something obvious.
The sidearms come preassembled for either driver side or passenger side mounting (i can't remember which for sure) so if you are mounting 2 on a vehicle one sidearm needs to be swapped so it is the mirror image of how it comes preassembled (so sidearm acess remains facing outside of the bike once a bike is mounted). The thule instructions are clear on how to do this, it is just a little time consuming. This part probably took longer than mounting them up. I can email you pictures of the racks mounted if you want to see how they look before committing....
Bumping up an old thread, as I haven't found any close-up pics, though I did find some forum members who are using these racks on the factory crossbars.
I picked up some Thule 594 Sidearm roof racks from craigslist, hoping to use them on my current Yakima rack. Unfortunately, I don't have enough Yakima crossbar extending to the outside of the base (i.e. where the Yakima base clamps to the 4R rail) to be able to mount the Sidearm on the outside. I would have to mount the Thule racks "inboard" of the Yakima base.
If I'm doing that, I may as well reinstall the 4R factory crossbars and mount the Sidearms straight to the factory crossbars -- they'll be closer to the roof (lower) and hopefully make a little less wind noise.
I know the Yakima/Thule aftermarket rack is stronger. But is there anyone here who has been using a Sidearm rack mounted straight to the factory crossbars, and using them for awhile now? Satisfied? Dissatisfied?
FWIW, I have the SR5 model, with the thin rails and flattened-looking crossbars. (Not the Sport with the tubular rails.)
