View Single Post
Old 02-12-2010, 04:10 AM
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Alright, here it goes...
Body lifts just lift the body, hence the name. The ground clearance can only be improved a little bit if you put bigger tires on.
Suspension lifts raise the body and frame together as one which allows for more travel. Since the tires stay on the ground but the body and frame go up, the tires can now travel farther upward before they max out. And since the frame and body are both raised by the lift you get the full amount of ground clearance as the lift (i.e. 3" lift = 3" of ground clearance). The only thing that doesn't get more ground clearance from the lift is the axle between the rear tires. Everything else.. the tranny, front diff, t-case, gas tank, etc.. does get the full improved ground clearance.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
