5th Gen Features/Models/Differences
SR5 Premium have two tone softex seats black/gray or beige 2tone
TRAIL Premium have black softex seats with red stitching
The Texas and other packages are something dealers cook up. The reason you see regional differences is that marketing has determined what will sell best in specific areas. You can only get those options in those regions so if you want something specific you have to travel there to get it.
Yea, I know they're done by dealers, but I'm fully prepared to travel if there's one that fits my needs and desires! Just need to find out what's out there now! ;-)
Cars.com or similar for the dealer mods. For the port installed options that are regional then:
Find major city zip codes in each region
Type those in to build what you want
Use the dealer locators on Toyota website to check their inventory.
What exactly do you want that is unavailable in your region? Start a thread with listing what specifically you want and someone here will likely tell you what dealer has what you want.
If you read the post I didn't break out the standard and premium models as that gets messy and unclear because of overlap. There is not a clear specific delineation between the two as some things could overlap. KISS
Pro model has information in the center dash
Trail model no longer has this feature and I am sure the did away with it in the Trail to make the Pro model seem more special.:wow2:
The Pro has the info display in the center gauge cluster just like the Trail. I think the center dash information display has been replaced with a simple clock for all models.
Alrighty now! I sold my '97 back in '13 and got a new/used Tundra. I'm giving that to the man and getting a new T4R.
I've read everything here. What in wanting to know is if there are any regional submodels? (The Tundra has SR5, Limited, base... But also, at least in the SE, there's a Texas Edition and a louisiana Edition.)
Is there anything like that out there? I am finding that regionally (SE) many dealers are only sticking certain options when I look at inventory in say, California, there's differing option packages.
Anyone know anything?
Apologize in advance if I screw this post up; first time posting in a forum. In response to Cuffs, the Southeast Toyota Distributor offers an XP package. I believe it is available on either of the SR5 or TE models. It is $2,999. You can go to the Toyota website and build your own using a SET zip code such as 33604. This package is installed at the port, not at the dealers. You can also check out the package at the following website: toyotaxseriesdotcom
Ok, thanks for clarifying this... I was confused, as I swore I test drove a '14 Trail that had the center info dash, but then the '15 Trail Premium I actually ended up buying does not, just a clock. I didn't even notice this until driving around for a few months and seeing a pic on here of a 14 Trail with one.
Not a big deal, as the info is available on the main instrument cluster, but thought for the last couple weeks I was either crazy or got cheated!
I'm talking about where the clock is, on the Trail it just a cheep clock and on the Pro it still has the information center. This is a screen shot from a Pro review.
Ok it seems the Pro shipped the same as the Trail w/no center dash display.
That pic is from the pre-production Pro. The production trucks are just like the Trails with the clock in the center of the dash. I can go take a pic of my Pro if you would like.
Does anyone know about removing the side body molding off of a 2011 SR5 being able to run rails that should be for a TE? I tried to read through everything but I thought someone might have some information for me. Thank yall so much!
in this thread? This is about the differences between models...
It is about the difference between an SR5 and TE.
this is considered a mod not an OEM feature, hence 1eng reply.
that's how I read yours and his reply.
Over the past month or so we have had quite the influx of either new 4Runner owners or those looking to purchase. With them in mind I wanted to start a thread listing the DIFFERENCES between models.
2015 LE model can have all the features that can be had on the SR5 and
-Push button start
-LE specific body cladding
-XREAS Suspension
-Full Time 4WD available
-Auto Headlights
-Dual Automatic Climate Controls
-JBL Sound and Speakers
-Leather trimmed seating
-Ventilated seats
-Keyless Touch Entry
-Memory Driver's seat
-Wood grain Interior
-Powered Running Boards
He didn't read my original post apparently. "LE specific body cladding" means exactly that. I made it bigger...
