Pulling Up Rear Seat Bottoms With Katzkin Installed
Lester Lugnut
2014 4 Runner SR5
Need to pull up rear sear bottoms(what you sit on). Page 128 of Owners Manuals shows pull rings similar to what I've seen in other SUVs.
I've gone thru this forum and have found photos of Katzkins that seem to retain this pull ring to lift up the seat.
My setup is different. No pull ring in sight. There is a velcro piece that runs across the back of the bottom cushion on each side of my setup - 60/40. Attached a photo with this velcro piece pulled down. On each end there is a slit and a plastic piece inside on each end. Thought maybe these 2 plastic pieces were used to unlock and raise the bottom cushions. If so, I've yet to come up with the technique.
Wondering if anyone here has a similar setup and knows how to get the rear set cushion bottoms up with this setup.
Thanks.
